SolSiForever
- Heza
- Oct 31, 2020
- 4
- 0
- Ohio
- 93 Civic del Sol Si, 2020 Civic Si
I've had my 2020 Si for a week now and I still have a lot to learn so my apologies if these are straight up dumb questions. I tried to search for a good downshift thread but wasn't finding one. My husband is an ok teacher but I feel there are some points he's lacking in since his manual experience was only ever in a truck 17 years ago. Since I'm a complete beginner (this is my first manual car) I need some help understanding what I should be doing.
Is there a good MPH range for each gear I should be aware of? I understand this will vary based on my goals and if I value efficiency, but a general idea would help me a lot. The car's guide saying to be in 6th at 39 MPH doesn't make sense to me. At 39 I'm probably in 4th. Right now I shift around 2.5-3k rpm since I'm babying everything in the break in period. Around town I rarely find a reason to get above 4th gear. Shifting up seems to make sense to me, it's easy enough to understand when to do that. What confuses me somewhat is downshifting. When, where, and why.
I know that there's basically no reason to shift into 1st unless I am crawling at 5mph or something. Is there a 1st gear lock out to prevent accidental shifts into first? I'm super paranoid about doing that and breaking it. I might shift down into second if I'm in the 10-15 range, and 3rd if I'm under 25. But after that it all becomes confusing. Doing 50 in 5th seems pretty similar to 50 in 6th. So I'm not really grasping when I'd downshift into 5th from 6th or even 4th from 5th. Right now if I'm slowing down from say 50 (I've yet to take this on the highway) I get confused. How slow is it ok to go in 5th or 6th without the car getting pissed and trying to stall? Until I understand downshifting from higher gears, I don't really want to highway drive. Is it better to just slow the hell down in gear and then skip into a lower gear vs sequential?
So basically a mental guide of "If I were in neutral (or slowing down from whatever gear) and I'm slowing down and need to pick a gear to speed up out of at X speed I should pick Y gear". Assuming I'm not above 3k rpm which at this point I never am. Points for explaining things in stupid baby terms lol.
Also can someone explain brake hold and if it would be beneficial to my roll back anxiety? Right now I'm super slow and cautious taking off in first as I learn my footwork, I tend to under throttle and need to fix that. Taking off on a hill is really fucking with me since I'm SO SLOW at take offs right now. If I stall with someone around I get a bad case of the jello legs. The automatic hill hold, if it does kick in, is only for a second and a half it seems and for me that's not enough time, so it isn't helping much. Would brake hold help this situation at all?
Lastly, how much is my car going to hate me if I don't use premium fuel? I don't have a problem using premium I just want to understand what kind of difference it makes.
Any other newbie tips to help me learn this car and manual in general would be much appreciated. Thanks!
