Battery ground terminal
PaulD
Paul
Huntsville, AL
2018 civic Si coupe, 2001 Accord Ex coupe
The parts page calls the battery negative terminal a sensor assy. There is a gnd wire AND a connector with two small wires on it. what do those wires do, where do they go ? What would happen if I just disconnected it ?
PaulD
Paul
Huntsville, AL
  • #3
Every single 10th gen civic has the same negative batt terminal. I assume if you are in here, you have a 10th gen civic.
BoostinIX
Laurel, MD
2020 SI Sedan
You're not hurting anything by having grounds... if you're asking about removing it I'll assume you have it. Why would you want to remove it?
PaulD
Paul
Huntsville, AL
  • #7
What if I want to use something bigger than the wimpy gnd cable it comes with ? Or ... gasp ... use after market battery terminals ?
shoegazer
Raleigh NC
2018 Civic LX Coupe 2.0 (CVT)
Short answer: I don't know the facts re: the secondary ground.
But given the shitshow of issues that can be caused by a bad battery, grounding, or even just a change in the resistance of all of the above; I'd personally stick with OEM. Although I can't think of a reason that a larger conductor would be a problem.
Edit: I will, however, warn you to not turn the screw too far when loosening the tension on the connector. Previous owners have done so and lost the locking nut in the bowels of the engine bay.
Gruber
Mark
TN
This is the battery sensor. Don't touch it.
pappazzz
Papa
Vic
Ok, but what about the battery is it sensing ? And where do the 2 wires actually go
you dont sound like you know enough to be playing around with it,
leave it alone before you mess up your car and then come back here blaming it on honda
Gruber
Mark
TN
It's sensing the current of course. The total current going to or out of the battery. The two wires send a tiny voltage drop on a very small resistance that's inside that clamp.
If you disconnect these wires the ECU will let you know and your charging system will not work.
PaulD
Paul
Huntsville, AL
  • #13
And now I remember why I never come here to ask a question. I get ZERO useful information that I didnt already knowand get told that I'm too stupid to mess with something no one else on here understands either. What an awesome place
PaulD
Paul
Huntsville, AL
  • #14
Finally, something useful. I will do a short trial run to see what happens
Gruber
Mark
TN
You still come, apparently. And you learn.:cool:
