GTAHatch
Hey everyone. I’m calling all base model 1.5T engine owners to come forward with some data logs. Hondata and Ktuner. I’ve seen a lot of post in regards to this but it’s focus on those post are towards the individual. So basically I’m looking for a wide range of people that are using different mods and tunes, but are using Hondata or Ktuner. I’m VitTuned using Ktuner. I can go WOT and make it climb. Start at .49. By the time I get to 6th gear I can between .80 and 1.10. I’ve done test beyond test. I’ve done compression test, intake manifold test and scope, checked plugs and respaced, check MAF, checked ignition boots, and so on and so forth. If I do a gradual throttle I can make it climb really fast.
Things I don’t want to hear.
It’s gas. Nope cause running ethanol.
MAF. Nope brand new.
Sensitive Microphone. Then why are some guys experiencing this and other aren’t?
The base model just does it? Why? Why does it do it? What’s causing it to do it?
Just cursious why this is happening and what we can do to stop it from climbing. Also my actual knock count stays at zero most of the time. I maybe able get a knock count of 3 to 5. Thanks in advance. Hope we can solves this. Also if elevations have anything to with it I’m in Toronto Ontario Canada.
