Banging noise from front end during wheel slip '19 Si
Luke Duke
Luke
Harford County
2019 Si
2019 Si coupe, When I break the tires loose, rain, snow or dry conditions, very loud banging comes from the front end. I just assumed it was the brakes grabbing for the traction control. However I tested that theory and it still does it with the traction control turned off. It's really loud, scares the crap out of passengers. Any ideas? It has done this since day one. Thanks!
PowerPerLiter
Specific Output
Midwest
You should avoid this scenario at all costs for the poor cars sake. Sounds like you have never had a fwd car that could spin a tire?
REBELXSi
Señor Member
Wheel hop. You need a rear motor mount upgrade OR a motor mount insert from perrin. This will fix your problems.
I have the Hasport 62A and the problem is still there but Ive launched my car less than 10 times in the nearly 2 years of ownership.
While this is true, we should also mention to the OP that this can often cause a significant increase of NVH depending on what rear motor mount solution is chosen.
amirza786
A
Northern California
Everyone else has already mentioned this, wheel hop. Not good for the car. Don't do it
bugboy32337
Tallahassee
2019 Civic Si Coupe (MSM)
charleswrivers
Charles
Kingsland, GA
Me 6 for wheel hop.
My RSX had floppy mounts and every time it happened you'd think the world was coming to an end. It's kind of akin to using an torquey electric drill with the chuck locked and trying to tighten/loosen something that's seized and the drill trying to jump out of your hand from the torque. Only it's your engine... trying to jump from your motor mounts as the wheel(s)... through your drivetrain transfers torque back to your engine… as your wheel(s) grab and lose traction again and again, your engine is rocking violently in whatever play exists in your mounts.
It's really... really fun with passengers though, especially if you scream while it's happening. When it happens... you're going to want to lift or risk shaking your fillings out... or causing harm to your car eventually.
It did always manage to evoke a "OHMYGODYOUBROKETHECAR" response from my wife... and was a source of joy when I was thrashing that old car. I wouldn't do it to something I care a lot about regularly.
Maroco
Martin
Tulsa Oklahoma
2012 Honda civic lx 2020 civic si
This is true. In this case i see nvh as the lesser of two evils. If he's driving his car hard enough to cause wheel hop he should take the steps to stop it. Nvh will be a byproduct. Everyone should research a product before commiting obviously.
Luke Duke
Luke
Harford County
2019 Si
True, that I have owned larger displacement rear wheel drive cars and trucks most recently. I have also owned several small engined front wheel drive cars too and I have never experienced this. I have done my share of drag racing, even cars that should not be raced. All of my cars are manual and sometimes I use tire slip like like how a clutch works to cheat and get the extra power. They never have made this noise. So what am I supposed to do? Anticipate the spin and back off the throttle? If so, this isn’t the car I wanted if it sounds like I’m going to break it every time I want to launch. I’ll be looking at mount upgrades, thanks for your help on this!
PowerPerLiter
Specific Output
Midwest
You very likely could break anything from "launching" any car. What was the end result of all your others? Broken?
I have a lot of FAST shit and rarely "launch" any of them.
Did you buy the car to sidestep the clutch at lights? If so then yes you absolutely bought the wrong car.
Luke Duke
Luke
Harford County
2019 Si
nope, my cars don’t break much, at least they don’t sound like they’re breaking while driving. Sure, I have blown motor mounts, snapped axle shafts, roasted clutches, and so on. I fix everything myself. I even mount and balance my own tires with my Coats tire machine and my Snap-On balancer (I have tools). It would be understandable if the car sounded like it was breaking while smoking the tires on dry pavement, but in mild rain when the boost comes in to play is not a normal time (for my experience at least) to have the engine sounding like its going to jump out of the hood. Just bought the Perrin inserts, we’ll see what that does. Thanks again for all your help, I do appreciate the feedback.
