Axle shaft bearing is leaking again
Drunkndude
So Cal
18 Honda Civic Si
The first oil change I didn’t on my car I noticed the axle shaft bearing was leaking. I took it into the dealer and they replaced it. Now it Is doing it again, anyone else having this problem?
zhendexing
Dee
Chicago
2018 civic si coupe
It loooks like engine oil to me. There are similar problems reported in this forum I
had some leaking when switching to idemitsu zepro 0w20 which is thinner than oem.
Drunkndude
Drunkndude
So Cal
18 Honda Civic Si
  • #3
Ive been using amsoil ss 0-20 and haven’t seen any leaks. It didn’t look like it was coming from above it but I will double check.
FlyNavy
Jon
CORPUS CHRISTI, TX
2019 Civic Si
I am having the exact same problem, same place, AND I use the same oil as you.
I'm kinda stumped. At first I thought it was oil but I chased the stream down and it didn't have an origin on the engine block and the valve cover gaskets are fine.
OP are you lowered?
I'm @ 6,000 miles on my 2019 SI, did the first oil change at 3,000 miles, there definitely was NOT a leak, now at 6k there is.
I'm lowered on Eibach Pros. I want (and plan) to take it to the dealer to get fixed, worried they might try and blame being lowered. In reality that should have nothing to do with it, because that part of the axle shaft is straight at all times and kept in place by the mount. The bearing must have gone bad.
Any one know if you can just replace the bearing itself?
FlyNavy
Jon
CORPUS CHRISTI, TX
2019 Civic Si
Where was the leaking from? OP and I both run Amsoil SS.
pinhead66
Bay Area, CA
2019 Civic Si Sedan, 2018 Odyssey EX-L
Are you lowered? Did the dealer hassle you at all or were they pretty good about it?
Not lowered and no hassle. It just took a week to get the part but no issues. You should be taken care of under warranty so don’t hesitate.
zhendexing
Dee
Chicago
2018 civic si coupe
From the passenger side of the engine I couldn’t tell where exactly it came from because it’s a really tight space
Drunkndude
Drunkndude
So Cal
18 Honda Civic Si
  • #10
Im not lowered but that shouldn’t matter. When I took it in they cleaned up the area and said the bearing must have leaked out excess grease.
