Awful Sound System On My New Civic
hicompb18c1
San Diego
2019 Civic Si Sedan, 2018 Accord LX (wife's)
Thanks for the info, everyone. Yeah, the sound drives me nuts. Plus, I'm a musician and I listen to all kinds of music. It's all bad. I don't understand much of what everyone wrote here and I don't want to take apart door panels and do other major mods, and possibly void the warranty. I guess 'm screwed. Otherwise, the car is great !!
I was able to Hondahack my head unit last night and install the Viper4Android app, which has some nice equalizer settings, and it definitely made a difference. It's still not a great system (my crappy head unit "skips" every so often, really annoying), but I do have fuller bass and at least *some* control over different frequency ranges.
Yoda
Chicago Suburbs
2016 LX MT
I've been in elevators with better sound systems than the stock Civic unit
SCOPESYS
Geoff
MD
The problem is with the DSP Processing in the Honda Amp, trying to make the pathetically Cheap Honda speakers sound better, to whatever stone deaf engineer at Honda who worked on this aspect of the sound system.
What is needed is some way to re-program the HONDA DSP,- something that it looks as if is possible, as Honda programmed it at the Factory to be the miserable performance that it . (it is programmed into EEPROM in the unit containing the AMP)
At least the non-premium system can have its DSP turned off, and set to FLAT.
So far, (as far as I know), nobody has figured out how to do this for the DSP in the Premium system's AMP, or better still, program it to a more desirable response.
Unfortunately, it will probably take someone like the Honda hack developer, to figure out how to do this, but whoever does, has the potential to make some good ( well deserved) money !!
xcivicx
whycanogaparkofcourse.
19 SI coupe in black
so far i'm not un-happy with mine. have yet to spend a good long 8 hour drive with it to really form my final opinion. short drive impression is that it sounds ok enough, but lacking. if i can go 8 hours and not be fatigued by the sound, i'll be able to go some time before any up grades.
hicompb18c1
San Diego
@SCOPESYS you're still running the OEM head unit, right? Do you play most of your music off the phone or USB?
SCOPESYS
Geoff
MD
On the OEM unit ( and Eonon in the Maxima) 95% of the time I just play Mp3 files from a 32GB USB flash drive, with either Poweamp of Blackplayer ,
I the 2018 Honda Si, my wife plays music 95% of the time from a 32GB USB flash drive, using the Honda MP3 (File based) player,
Occasionally, we will use Spotify, (for something new) although with 32GB of music, it will take YEARS to play it all !!. Music tends to sound better direct from MP# on the head unit, rather than Bluetooth from the phone.
With the updated CENTER speaker in the SI, the overall sound is quite acceptable for most music that we play - we both still have good hearing (despite the numerous Rock Concerts we attended in our youth) !! - so we seldom turn the Honda up past about a Max of 15.
hicompb18c1
San Diego
Good to know, thx. I haven't tried downloading files to a USB directly yet so I'll have to try it.
I did copy your center speaker upgrade (the JL) - it definitely sounds cleaner. Now I just notice my stock tweeters might need to go too!
SCOPESYS
Geoff
MD
I think the main improvement with the replaced center speaker, is that it is less sensitive, so it does not drown out the two door speakers.
You can now hear a better stereo separation, and the bass from the side speakers is significantly more than from the center one in any case, so the overall impression is that there is more bass, as you can tune the volume up a few levels, without the center speaker being the dominant speaker, with its lacking in bass.
Yoda
Chicago Suburbs
2016 LX MT
[QUOTE}At least the non-premium system can have its DSP turned off, and set to FLAT.[/QUOTE]
How does one do this?
19redsi
Virginia
2019 Si Sedan
So - to summarize:
you believe the signal going from the head unit to the amp to be full-range/good quality (and non-standard optical?)
you believe the DSP on the amp itself is what alters the signal and results in crappy sound
you don't think it's the crossovers built into the amp that is messing with the sound quality (unless the crossovers are programmed in with the DSP vs being a separate program or physical interface)
Does that seem fair?
kperalta
AluminiumCivic
Colorado
2016 Honda Civic Touring
So - to summarize:
There's wiring diagrams and all the speakers are active including tweeters.
19redsi
Virginia
2019 Si Sedan
Okay, so, the active crossover splits the signal and sends it to independent amplifier modules which then pass the signal on to the respective speaker. Is an active crossover a separate thing from the DSP or is it all intertwined?
kperalta
AluminiumCivic
Colorado
...what?
A DSP is a Digital Signal Processor that processes the audio. It uses the software that splits the signal at the source and is either a) at the amp or b) before the amp. There are no "individual amplifiers". That doesn't exist. If it does, it shouldn't exist.
19redsi
Virginia
2019 Si Sedan
...what?
The wikipedia article states that an "active crossover" is one that splits which is then sent to amplifiers/amplifier modules before sending the signal out. That's what I was going off of.
https://en.wikipedia.org/wiki/Audio_crossover#Active
Mikeybc
Northern Ontario
2017 Civic Coupe EX-T, 2015 Nissan Murano
How does one do this?[/QUOTE]
Simply set bass treble and midrange to the middle position, or hit default.
