Fountainhead
- ray
- Jul 23, 2019
- 27
- 1,038
- 570
- Orlando FL
- 2019 Honda Civic Type R
Further update of the Infinity Center channel speaker.
I've found that using (don't laugh) lens cleaner cloth over the drivers grill works quite well at filtering out the objectionable frequencies.
I've attached a graph.
The cloth also works well on the tweeters. I've ordered black lens cloths that are 12" square and plan on using them as filters.
We tried 1st and 2nd order low pass filters of varying slopes, -3db points and none of them worked as well as the cloth, (there are not xover experiments on this graph) as you can see from the sweeps on the attached pdf. (Not accurate to 1W 1 meter just a response curve). The dip at around 1K was an anomaly from my test baffle size, not infinite but not small either.
Also, I forgot to mention I disconnected the 3.5 tweeter as it was quite harsh and one note.
Again, I feel the need to state "it's not perfect but a helluva lot better than it was", etc.
The factory driver was waaaay down in sensitivity from the Infinity.
BTW the Infinity stated it was "91 dB" sensitivity but actually measured much lower, ( that graph is not included).
The yellow curve should be "tweeter with cloth".
