Audio Upgrade Advice
cestjoel
2017 Civic Hatchback Sport CVT
I would like to replace my factory speakers with something affordable that drops right in like Polk DB 652 but Crutchfield says the Polk DB 652 does not fit my 2017 Sport Hatchback, is anyone running these in the front or rear doors?
The DB652 should fit. The DB651, won’t.
arhncmh
It's not my fault, really.
Harrisburg, PA
2017 Civic LX Sedan CVT
I'd like to install the DB652 front and rear in my 2017 LX Sedan, but as mentioned in this thread, Crutchfield says they don't fit. Not that Crutchfield is the be all end all, it's just that they're the best information I have available. Do you by chance have personal experience installing these? They are rated high by several reputable sources so I'm interested and would be glad to discuss with someone from Crutchfield on the phone regarding why they're saying they won't fit. Thanks!
nags
2019 Honda Civic Sport
Anyone just keep it simple and do the DB652 all the way around?
FK7Hatch
FK7Hatch
MD
17' Civic Hatchback Sport
I did DB6502 Front and DB652 Rears, they fit, but are tight inside the adapter ring where the plugs connect to it.
nags
I'm just thinking for simplicity sake doing the 652 all around and still an upgrade over stock.
Rycomm
Ryan
KC Metro
18 Civic HB Sport 6MT Aegean Blue, among others...
Polk db or mm 6.5" should fit with no issues. If you don't want to go to the trouble of adding the tweeters, the coax will be fine. I was quite surprised the imaging of the factory speakers. Sound higher than their low mounting location.
nags
Any amp recommendations?
SCOPESYS
Geoff
MD
YES... DO the speakers 1st...
They will give you the Biggest bang for your buck, and are relatively simple to do yourself.
Then if you are still not satisfied with the vast improvement you will get from some higher end speaker, only then start thinking AMPS.
AMPS is far more complex to install and set up correctly.
nags
I always do amps with all my cars. I wouldn't bother with just the speakers. Everyone just seemed to side so heavily with the Polks I thought maybe they had an amp of choice as well.
86salmon
It's Hedley, Hedley Lamarr!
Chucktown, SC
Head unit, budget, and system goals are going to heavily influence amp choices.
I went with Audiocontol in my si since they have a mono amp with bass processing and line level inputs for integration with the stock head unit. It's pushing a dvc 8 suited for my goals. Good clean power
My truck has rca output going to an older Massive 5 channel amp pushing components up front, coax in the rear, and a dvc 10.
In the past I've used MTX ( original Thunder amps, so beastly), Profile (are they even around any more?), Orion, and Fosgate with good results. Kenwood, not so much
