angerthosenear
Vehicle:
2016 Civic EX-T 1.5T
All stock parts, K&N air filter, but still stock airbox.
Stock tune and Hondata +3/+6 makes no difference
97k miles
New spark plugs (NGK Laser Iridium)
Using premium fuel (93, USA)
First time running any tune (under 100 miles tuned)
Situation:
When driving (sitting in park and revving doesn't do this), and accelerating around 2000 rpm I'll occasionally get a notable stutter. Audible light pinging / knock can be heard. Car stutters a bit before continuing. If I give it more throttle before 2000 rpm it'll skip past this 2000 rpm bad zone and rev fine at 3k+ rpm. Notably has to have some load through the drivetrain. Since cruising at 2k rpm seems fine, it's just when accelerating at 2k rpm.
While yes I see lots of people say not to worry about knock count and look at knock control, the knock count here climbs from 0 to 10 on a random cylinder rapidly. Knock control goes from mid 50s to over 100 - 120+
After I get past this point and fiddle with the throttle everything is back to normal. The knock stops and the knock control eventually falls back down.
I've tried various pulls on stock tune, Hondata +3 tune, Hondata +6 tune. The tune used doesn't make a difference for when this occurs. It's easier to trigger the stutter when on any non-stock tune, and started after I first tried the +3 tune. While it does seem like the cause, even reverting to stock I still have the same issue. Could just be a coincidence due to age. Or some failure of a physical part after this. Maybe a failed mount and the powertrain is just clunking / heatshield? I know the knock sensors are just microphones, so I'm not sure if the heatshield banging around is just the right frequency for the knock sensor to trigger. Inspecting the engine bay however, everything seems fine.
It's a higher pitched pinging noise, and doesn't sound like rod knock since it doesn't do it when idle or revving in park. I'm not familiar with various knock noises specifically. And looking at YouTube videos about them is oddly difficult, but could be my search terms. Seems more like detonation / spark knock from what I can find though.
I have attached a couple data logs from Hondata logging. One from a shorter run with some knock, and another from a much longer drive. The ones with a 2 are the return trip. The main runs are with the Hondata +6 tune since it's the easiest to get this to trigger.
Posting this in the general thread since it also occurs on a stock tune.
97k miles
Situation:
