Doc_Mello
- Apr 29, 2019
- 45
- 4,616
- 7,356
- California
- 2019 CBP Si Coupe
- Build Thread
- Link
- Vehicle Showcase
Good info.1. It isn’t the torque spec or clamping load that is the weak point with the factory head bolts, it is the metallurgy. I would not recommend torquing them over spec either because, unlike studs, bolts are subject to high torsion as you perform final torque and you risk weakening or even shearing them. Not a fun time.
2. Minimal. Despite the heat and forces of the environment that head bolts operate in, the bolt heads are constantly bathed in oil and the threads are effectively sealed from exposure meaning that corrosion and galling is virtually nonexistent and so breakaway torque is low enough as to not risk shearing a bolt unless they are already severely compromised. Not impossible, just extremely unlikely.
What about replacing 8 of the bolts with studs. Really don’t want to mess with the HPFP, nor that metal cam plate.
