AREA's 18 MSM SI Coupe build! LABWORKZ
Bryce.exe
ex Honda tech, now CEO/Project Manager
Bryce
Fargo ND
1988 CRX Si, 1992 Civic cx, 2010 Civic Si, 2008 RIdgeline, 2018 Civic Si turbo
What delete kit did you buy? I got one off ebay, its a must have for the si. My chrome had rail dust rust even when it was less then a month old with 3 miles on it..
AREA
AREA
Houston, TX
18 Civic SI coupe
Yeah one off of ebay! The name is in my original post. I just barely got around to installing it. I like the look of it.
EDIT: BRAND KHROME DELETE
NYK20Z3
Will
NY
06 Civic Si, 2017 Accort Sport
Excellent work the tint really tied everything in on MSM....
Zcfc3dc5
Zach
Wintersville Ohio
2018 civic si, 2002 Acura rsx type s, 2011 Nissan Titan
How much of a pain was it to do? I found the kit for $50 on eBay and I’m trying to decide if I want to do it myself or go to a vinyl shop
AREA
AREA
Houston, TX
18 Civic SI coupe
It wasnt that bad. I used a spray bottle with water, something hard and flat credit card shaped to scrape out excess water and an exacto knife. I first cleaned the chrome big time with some alcohol. Don't do it when it's windy or just do it inside the garage. Drench the chrome with water and lay down the strip. Align the bottom of the chrome up first. Apply water, repeal and apply as needed. Be sure to start at the from or back of the vehicle and meet where the door opens and closes. You will need the exacto there at the end. Once you have placed the vinyl in the right position scrape the vinyl with the card to remove the water under the vinyl. Repeat same process on the other side.
Zcfc3dc5
Zach
Wintersville Ohio
How long did it take you?
Zcfc3dc5
Zach
Wintersville Ohio
Shit to get it perfect less than an hour. Had to figure the best method. If I were to do it again maybe 20 mins.
Damn that ain’t bad at all. Looks like I’m gonna order them, I can’t stand the chrome
AREA
AREA
Houston, TX
18 Civic SI coupe
A couple new parts came in. @PRL Motorsports clutch line and a plaque for the shifter area. The plaque may be a bit large not sure if it will fit.
Honda Civic 10th gen AREA's 18 MSM SI Coupe build! LABWORKZ 45738277675_1fa9bf275a_k
AREA
AREA
Houston, TX
18 Civic SI coupe
Another part just showed up! New Circuit Hero shift knob. 500+ GRAMS!!!
Honda Civic 10th gen AREA's 18 MSM SI Coupe build! LABWORKZ 45752953105_bce2b50de1_k
AREA
AREA
Houston, TX
18 Civic SI coupe
New Shift knob installed! Front lip should arrive later today!
Honda Civic 10th gen AREA's 18 MSM SI Coupe build! LABWORKZ 45944610524_c5c248ae19_k
Honda Civic 10th gen AREA's 18 MSM SI Coupe build! LABWORKZ 46669462511_9414bdac65_k
