AREA's 18 MSM SI Coupe build! LABWORKZ
Speedy02
Javy
Miami, Fl
17 Si, 89 Crx, 91 Mr2
Its already in the mods on the flashpro. Ktuner was the one you had to ask before
Yea am running the race maf calibration atm with my own custom short ram and it made quite a difference, cant wait to put the cai, it should get here on the 4th
Bryce.exe
ex Honda tech, now CEO/Project Manager
Bryce
Fargo ND
1988 CRX Si, 1992 Civic cx, 2010 Civic Si, 2008 RIdgeline, 2018 Civic Si turbo
Love the build so far! Looking great, it appears we must have similar taste.
AREA
AREA
Houston, TX
18 Civic SI coupe
Oh snap we do! We even have the same license plate frame lol. Will show pics tomorrow of the intercooler. It should be here!
demoPEng
Ham, On, Canada
2018 Civic Si Sedan, 2014 Ninja 300 SE
Sweet build man. I will be looking to get a lot of the same mods as you chose to go with in the next year or so.
AREA
AREA
Houston, TX
18 Civic SI coupe
Heck yeah man! I am loving this car. Just waiting for the MAP exhaust to come in. Not sure how much more I am going to do because i bought another car I want to mod. We will see!
AREA
AREA
Houston, TX
18 Civic SI coupe
New @MAPerformance exhaust arrived!!! Missing pipe already on the way! Can't wait!
Honda Civic 10th gen AREA's 18 MSM SI Coupe build! LABWORKZ 20181005_212003
Honda Civic 10th gen AREA's 18 MSM SI Coupe build! LABWORKZ 45297258875_b4671461b3_c
AREA
AREA
Houston, TX
18 Civic SI coupe
@MAPerformance exhaust install!
Old exhaust removal process:
There are 7 exhaust hanger rubber bushings. Before starting i sprayed all bushings with a generous amount of wd40 and let them sit for a few mins.
Honda Civic 10th gen AREA's 18 MSM SI Coupe build! LABWORKZ 32376565478_477ea85a94_c
I used a pry fork to slide off the bushings from the old exhaust hangers.
Honda Civic 10th gen AREA's 18 MSM SI Coupe build! LABWORKZ 44431719890_5c9c97ddf3_c
Lets look at hanger locations
The rubber bushings for these two can stay on the exhaust and not the car!
Honda Civic 10th gen AREA's 18 MSM SI Coupe build! LABWORKZ 45523709284_716487bf9c_c
Honda Civic 10th gen AREA's 18 MSM SI Coupe build! LABWORKZ 45334609715_c95916b4ac_c
Notice 4 in this center section. These are the only muffler mounting points for the MAP exhaust.
Honda Civic 10th gen AREA's 18 MSM SI Coupe build! LABWORKZ 46247617551_bbe7069cc1_c
The last hanger is in the resonated mid piping shown
Honda Civic 10th gen AREA's 18 MSM SI Coupe build! LABWORKZ 46247480291_68aab6db67_c
Exhaust removed!
AREA
AREA
Houston, TX
18 Civic SI coupe
Now for the new @MAPerformance street exhaust:
Tools used rachet, 14mm socket, 15mm socket and deep 13mm socket.
I started with the muffler section.
I lubed all 4 of the muffler hangers so they would slide easier into the hanger bushings. 2 bushings per muffler side.
Honda Civic 10th gen AREA's 18 MSM SI Coupe build! LABWORKZ 44430457710_13811d927b_h
Honda Civic 10th gen AREA's 18 MSM SI Coupe build! LABWORKZ 31308418327_eb591ae4c0_h
Muffler is now hung!
Honda Civic 10th gen AREA's 18 MSM SI Coupe build! LABWORKZ 45334526275_f87b0a2f73_c
Next I installed the front section of the exhaust (3 bolt flange) using the provided new gasket and new bolts, tightening with a 14mm socket.
Honda Civic 10th gen AREA's 18 MSM SI Coupe build! LABWORKZ 46247627411_c19be19df0_h
I laid out all of the new piping following the curvature of the factory piping.
Next I installed a vband clamp over the front piping.
Honda Civic 10th gen AREA's 18 MSM SI Coupe build! LABWORKZ 46247729041_aa5649a64d_h
Lubed new hanger and mounted up the center resonated piping tightened vband snug to prevent movement but not too tight.
Honda Civic 10th gen AREA's 18 MSM SI Coupe build! LABWORKZ 44430649410_2bc1cdf087_h
Honda Civic 10th gen AREA's 18 MSM SI Coupe build! LABWORKZ 46196992312_6eefa32b62_h
Honda Civic 10th gen AREA's 18 MSM SI Coupe build! LABWORKZ 46197000332_ec22399c8b_h
Honda Civic 10th gen AREA's 18 MSM SI Coupe build! LABWORKZ 32375440628_e30accab4c_h
Next slide exhaust clamp over the resonated piping. Next I bring the additional piping over and slide the clamp over the two pipes equally (eyeball it). No tightening here!!!
Honda Civic 10th gen AREA's 18 MSM SI Coupe build! LABWORKZ 46197098252_95d751ba3f_h
I slide a vband clamp over the muffler piping. I connect the mid piping to the muffler with vband clamp and tighten snug but not too tight!
Honda Civic 10th gen AREA's 18 MSM SI Coupe build! LABWORKZ 46247862261_7c57661784_h
At this point everything is together loosely this is the time to check piping clearances to the body and eliminate potential vibration points of the exhaust on the chassis.
Once clearances are checked tighten the vband bolts with 13mm deep socket and the exhaust clamp with 15mm socket. and you are done!
Honda Civic 10th gen AREA's 18 MSM SI Coupe build! LABWORKZ 32376564998_ec84d18e9e_c
