AREA's 18 MSM SI Coupe build! HTXGENZ
Speedy02
Javy
Miami, Fl
17 Si, 89 Crx, 91 Mr2
Its already in the mods on the flashpro. Ktuner was the one you had to ask before
Yea am running the race maf calibration atm with my own custom short ram and it made quite a difference, cant wait to put the cai, it should get here on the 4th
AREA
AREA
Houston, TX
95 hatch Drag car, K20Z3 00 Integra, 07 Civic SI sedan and 18 Civic SI coupe
  • #17
Just loaded the @Two Step Performance stage 1 tune. Runs great! Intercooler arrives Friday! The MAP exhaust is 3 to 4 week turn around!
Bryce.exe
ex Honda tech, now CEO/Project Manager
Bryce
Fargo ND
1988 CRX Si, 1992 Civic cx, 2010 Civic Si, 2008 RIdgeline, 2018 Civic Si turbo
Love the build so far! Looking great, it appears we must have similar taste.
AREA
AREA
Houston, TX
  • #19
Oh snap we do! We even have the same license plate frame lol. Will show pics tomorrow of the intercooler. It should be here!
AREA
AREA
Houston, TX
  • #20
AREA
AREA
Houston, TX
  • #22
demoPEng
Ham, On, Canada
2018 Civic Si Sedan, 2014 Ninja 300 SE
Sweet build man. I will be looking to get a lot of the same mods as you chose to go with in the next year or so.
AREA
AREA
Houston, TX
  • #24
Heck yeah man! I am loving this car. Just waiting for the MAP exhaust to come in. Not sure how much more I am going to do because i bought another car I want to mod. We will see!
AREA
AREA
Houston, TX
  • #25
New @MAPerformance exhaust arrived!!! Missing pipe already on the way! Can't wait!
AREA
AREA
Houston, TX
  • #27
AREA
AREA
Houston, TX
  • #28
@MAPerformance exhaust install!
Old exhaust removal process:
There are 7 exhaust hanger rubber bushings. Before starting i sprayed all bushings with a generous amount of wd40 and let them sit for a few mins.
I used a pry fork to slide off the bushings from the old exhaust hangers.
Lets look at hanger locations
The rubber bushings for these two can stay on the exhaust and not the car!
Notice 4 in this center section. These are the only muffler mounting points for the MAP exhaust.
The last hanger is in the resonated mid piping shown
Exhaust removed!
AREA
AREA
Houston, TX
  • #29
Now for the new @MAPerformance street exhaust:
Tools used rachet, 14mm socket, 15mm socket and deep 13mm socket.
I started with the muffler section.
I lubed all 4 of the muffler hangers so they would slide easier into the hanger bushings. 2 bushings per muffler side.
Muffler is now hung!
Next I installed the front section of the exhaust (3 bolt flange) using the provided new gasket and new bolts, tightening with a 14mm socket.
I laid out all of the new piping following the curvature of the factory piping.
Next I installed a vband clamp over the front piping.
Lubed new hanger and mounted up the center resonated piping tightened vband snug to prevent movement but not too tight.
Next slide exhaust clamp over the resonated piping. Next I bring the additional piping over and slide the clamp over the two pipes equally (eyeball it). No tightening here!!!
I slide a vband clamp over the muffler piping. I connect the mid piping to the muffler with vband clamp and tighten snug but not too tight!
At this point everything is together loosely this is the time to check piping clearances to the body and eliminate potential vibration points of the exhaust on the chassis.
Once clearances are checked tighten the vband bolts with 13mm deep socket and the exhaust clamp with 15mm socket. and you are done!
AREA
AREA
Houston, TX
  • #30
Now for sound clips!
Test Drive time!!!
