Are Type R front strut bars compatible with non-Type R hatchbacks?
echoparkpanda
2017 Civic Hatchback
Just curious as I've seen some sellers list them as compatible but want to confirm before buying or passing on the item.
Honda Civic 10th gen Are Type R front strut bars compatible with non-Type R hatchbacks? IMG_8019.PNG
Stigglesworth
New Jersey
2020 Civic Hatch
My research says the answer is: "Yes", but I don't have first hand knowledge of it. From what I could gather the Type R bar is bent differently to route around a part of the Type R's engine, but would fit on the other hatchbacks as they have a smaller engine that will not interfere. It would be good to get a more concrete confirmation of that, though.
thatbvictor
Brandon
Mad city, Wi
Civic Sport HFP
Isn't the suspension wider on the Type R? I wouldn't think that the strut towers would be the same distance apart if so
123sillyboy123
2019 CTR
Took some pic for those who interested
J's bar is for CTR,
UR white bar is for 1.5 sport hatch.
I did the experiment and can confirm that type R strut bar wont fit regular civic. At least not hatchback.
Honda Civic 10th gen Are Type R front strut bars compatible with non-Type R hatchbacks? 20200101_163645
Honda Civic 10th gen Are Type R front strut bars compatible with non-Type R hatchbacks? 20200101_163658
Honda Civic 10th gen Are Type R front strut bars compatible with non-Type R hatchbacks? 20200101_163701
Honda Civic 10th gen Are Type R front strut bars compatible with non-Type R hatchbacks? 20200101_163942
Honda Civic 10th gen Are Type R front strut bars compatible with non-Type R hatchbacks? 20200101_163937
Honda Civic 10th gen Are Type R front strut bars compatible with non-Type R hatchbacks? 20200101_163934
JT Si
Place
Car
The suspension is wider because of the different knuckle design. The strut towers are the same.
123sillyboy123
2019 CTR
weird. The ebay ad puts the Hatchback with the Type-R.
If you look at Megan Racing's website, they describe the standard tower strut bar to exclude the Type-R and Hatchback.
There's a separate product for the Type-R, but it makes no mention of Hatchbacks.
Probably should give them an email to clarify.
I took the UR bar off yesterday, tried to put it on the ctr, it is off by 2mm for one bolt, i can enlarge the hole on strut bar wide by 2mm and it will bolt on CTR.
I also took the J's strut bar off the ctr and put it on sport hatch, it is off by a mile...
You can refer to the picture below, it is the J's bar on sport hatch.
Donkeyhotay123
HB
2019 Civic Hatch
Do you have to loosen the bolts securing the bar to the mounts to get it at this length?
I notice the SiriMoto will fit all models including Hatchback, in exception to the CTR.
I have the SiriMoto bar and hatchback, but no ctr to test this.
123sillyboy123
2019 CTR
I did try loosen the bolt on both side... the type r bar fitment on hatchback is not even close.
