i cant name the engineer but after speaking with a japanese engineer on the CTR project from the beginning I was told that the hood scoop was originally designed with a true function, but in real world it was found to not provide any real improvement as intended and the dies to stamp the hoods has already been created so they kept it and added the channel to the underside simply to direct water to either side rather than down onto the intake manifold area.....take this information as you wish
actually now that you mention this.... my dealer drove around my car getting it PDI'd with the hood scoop still covered in the white vinyl material from shipping. They got a Check Engine code and told me that it was due to it being wrapped shut. But they did not tell me what the code was...
Yea, I've also read that the scoop was an afterthought. However, Honda does say it aids in “general engine bay cooling” and "contributes to the Type R’s stability by sending air into, through, and under the car" as well as "reduce lift at speed by relieving pressure from underneath" (similar to the second statement).Also don't forget this thread, some people have the black foam covering the front vent as well.
https://www.civicx.com/threads/black-foam-blocking-air-vent.17142/
You are right on the brake ducts. My air curtain ducts show a clear line of sight between the intake and the wheel liner holes, so having something blocking them is probably an assembly mistake.Yea, I've also read that the scoop was an afterthought. However, Honda does say it aids in “general engine bay cooling” and "contributes to the Type R’s stability by sending air into, through, and under the car" as well as "reduce lift at speed by relieving pressure from underneath" (similar to the second statement).
That would suggest that something under the hood could overheat and throw a code if the scoop was removed.
¯\_(ツ)_/¯
I looked at that linked thread and it is strange to have foam behind those vents as they directly exit into your wheel well to "optimize stability at speed". Even though these are still 100% effective, the thread comments state that those are the brake vents, but I think the brake vents are the vents located underneath the fake/solid "vents" between our fake carbon fiber and our real paint. Please correct me if I'm wrong though.
I know that's not the point of that thread, so I apologize for taking it another direction.
Speaking of vents and airflow what about the European under hood fender panels. I am picking up a set in Spain. How will installing these panels affect heat flow out of the engine bay?Was watching the Carfection review and noticed that the fender vents on the rear looked like it was blocked off, like a solid piece of plastic. Thought rear fender vents were functional to blanket the side skirts with air. Can someone confirm that they are indeed functional or blocked?
