Anyone upgraded from stock 16s to 18s? How was it?
BarracksSi
DC
Just switched from my 16" winter set on steel rims back to the stock 18s.
The steel setup was lighter, too, something like 3 lbs per wheel (215/55-16 Pirellis on 16x6.5 steel rims: 45 lbs; reported OEM 18x8s w/ 235/40: 48 lbs).
The 18s hit harder on cracks and seams. Generally, the ride seems the same, but the same sharp pavement cracks I drive over every day make me wince more when the car is on 18s. The sidewall is about an inch shorter on the 235/40-18s (~8.1" vs 9.1"), which is more than a 10% reduction in cushioning, too.
Maybe turn-in is sharper and maybe there's less squidginess in turns, but daily driving with traffic on public roads isn't stressful enough to find the difference.
W1NTER
W1NTER
LaFleur
Civic X 1.8L CVT Sedan
Thanks for the insights.
This 10% reduced cushioning can be translated to a 10% faster wear in suspension components then? Or nothing to worry if I only plan to keep it for 5-7 years?
I think I'm fine with the slightly bumpier ride .
BarracksSi
DC
Nothing to worry about if you're only keeping it for 5-7 years. I think heavier wheels add to suspension wear, but surely Honda had these in mind during the car's development.
a c i d.f l y
Austin
Last time I rotated my tires on my '18 Civic EX I weighted my stock 16" wheel and tire. Total weight was 43.5 lbs.
Was that with the Firestone tires? Mine ranged between 45 and 46 with <400mi.
W1NTER
W1NTER
LaFleur
I am going from the stock 16s to 18x8.5 I am most likely going with Enkei TY-5 wheels they look great and Enkei has a good reputation
I think most Honda wheels are made by Enkei. Please do update us on the changes you'll notice when you go 18s.
Dying2Live
Lakewood Ca
2018 LX Sedan Manual
Did anyone going from 16 to 18 have to get alignment? For the 2017 Accord when I went from stock 17 to 19 it made my car drive weird. Honda uses different alignment specs for Accords with 17 wheels and 18+ wheels. Front suspension between Accord and Civic look very similar
Viper
Muhammad
Islamabad
2020 Civic 1.8L
Hi! Same question here. My Civic is also with the 1.8L R18 with the current CVT. There are mainly two options in my country (Pakistan) as under:
Civic 1.8L Oriel with crappy 215/55-R16 tires and Civic RS Turbo (1.5T) with 215/50-R17 setup.
Suspension components used in both vehicles bear the same part numbers. I want to size up to 18" wheels whilst one trim is already in production with the 17" wheels/tires setup as above. This is a daily driver. The roads are not something to brag about either.
What should be the optimum width, off-set of the wheels and profile(s) of the tires to consider so as to put minimum effect on the ride quality/ suspension longevity.
P.S: Fuel economy is not a major issue here
Viper
Muhammad
Islamabad
2020 Civic 1.8L
I'm alternating from my 19" setup and my stock 18"s and the 18s ride great. If you use stock tire profiles (235/40Zr18) you will not have any issues. The ride is sporty, and responsive. again, avoid rep wheels.
Your Civic must have a suspension with adaptive damping if I'm not wrong. What about the 18" wheels on a basic base model sedan trim? Any ideas?
arpypat
Civic
If you move to 18s, then get 235/40r18. That is the recommended tire size for OEM 18x8 +50 wheels that come on the Si and Sport models in other countries.
Viper
Muhammad
Islamabad
2020 Civic 1.8L
Unfortunately, the widely available tire size is 225/40-R18 or 225/45-R18 and there was a noticeable difference in weight of both.
