Anyone running Type R Shifter assembly with Acuity Stage 2 shift kit?
Masked
Jos
Quebec, Canada
'18 Civic Si Coupe
What is the part # for the 2020 CTR shifter assembly?
ManitobaSI
Scott
Manitoba, Canada
2017 Civic SI
I’m installing the 2020 type r shifter tomorrow and transferring all the acuity parts I already had installed. Also installing this bad boy too! I got it from ICB motor sports.
Honda Civic 10th gen Anyone running Type R Shifter assembly with Acuity Stage 2 shift kit? A26E5A37-9565-41E2-82F8-15DDE11D2988
jakdotdot
Cali
2018 SI
Which acuity parts? Some shouldn't be put on the 2020 shifter. Assuming you are running the SI shifter and not the old previous CTR shifter.
As for shifter settings in general, You can absolutely go to short, IMO. The shorter the shifter, the more effort it takes to shift. Going too low can completely ruin the shifting experience. This is why counter-sunk shift knobs are noticeably heavier than stock knobs. the extra weight helps with the extra effort it takes to complete the shift.
rhino
jacob
Weeb land!
2015 sr5 access cab, 98 civic hx ej7, 2003 KLX400s
thats the issue i had with my countersunk shift knob on the type r setup
oilerlw8
Eric
So Cal
2018 Civic Si Coupe
FWIW, went from the short shift adapter with centering spring to the full shifter. On the recommendations from Acuity, gate spacing set in the middle, throw almost full short, height to one click above shortest. Acuity mentioned that the shifter being metal over the stock plastic would make a big difference and this seems to be very true. Each shift kind of "schnicks" in (not sure if that is a real word). As mentioned above, the weight of the shift knob has big effects. Using a Skunk 2 and a Blox (around 450gms) and also a S2000 aluminum (150gms). It was hard to justify the price, but considering shifting the car is something that is done EVERY time it is driven was the compelling factor. Again, just personal opinion, but so far the absolute best mod on the car...
rhino
jacob
Weeb land!
I don’t have the acuity shifter and don’t plan to own it tbh but I have a shift knob that weighs almost nothing and it goes into gear with crazy ease compared to my countersunk and weighted because of how low it sat here is a pic of it
Honda Civic 10th gen Anyone running Type R Shifter assembly with Acuity Stage 2 shift kit? B2B2F3FE-2AC9-4A7C-BB79-75B51EB3A648
BoostinIX
Laurel, MD
2020 SI Sedan
Just ordered both instead of just buying the full acuity shifter kit specific for the Si, wondering if any of you have tried out both and want to know your thoughts on them.
Saved about $275 going the Type R assembly route and I know it's already 25% ish shorter throws, curious if that extra $275 is worth it for some minimal differences
You got the Stage 2 kit for the FK8 right? Don't run the short shift adapter on the Type R shifter. Also can do the zip tie method as long as you're in there to ensure there's no clunking.
I have this setup on the 2020 CTR shifter and it's awesome for DD. Worth every penny.
Mcclaughry95
500hp is the goal.
Ryan
Central, Pa
18 Civic Si
I'm running the short throw adapter from perrin on my type r. Waiting to see if the cable fails from the extra wear they say it causes. Worse case new cables and take it off then.
suhhh
suhhh
Kenny
North NJ
Current: 2020 Civic Si Coupe Past: 2018 Civic Si Coupe, 2014 Prius, 2013 Civic LX 5spd
Yes stage 2 kit for fk8
I'm able to run everything on there with the assembly right?
suhhh
suhhh
Kenny
North NJ
fenix-silver
Central PA
2019 Si
suhhh
suhhh
Kenny
North NJ
thanks man im soooooo excited to throw all this shit on paired w esco shifter lol
when I had my 2018 si and when i first got my 2020 I always thought stock shifter was good. Then I got a new job and was forced to drive in a lot more traffic combined with some really tired mornings
started noticing the slop a lot more and notchiness and it started getting more tiring to row through gears consistently
