To keep OEM backspacing, you need the same offset as stock, which is +60Just wondering if you guys are doing +41 because the back spacing will be equal to oem setup for centerline of wheel?
Have you guys fitted the 18x10 yet?
https://www.willtheyfit.com/index.p...t2=35&wheel_size=19&wheel_width=10&offset2=60
Assuming that with +60 offset (OEM) you are the closest you can be to the suspension, if you go to 10" you add 16 mm of extra width on each side, which means that ideally you should have a +44 offset to get the same backspacing as with +60 with a 10" wheel!Not when the wheel is 18x10
You get photos of these installed??I will be running federal Rs-rr 265/35 tires on volk te37 +41 offset. The Rs-rr runs a size bigger so it’s more of a 275 instead of 265
