Anyone running 18 x 9.5 +35?
Chubs77
Ali
2020 Civic Si
I’m looking at getting some MST MT30s and that’s the only size they offer them in. I’ll be on stock suspension for the foreseeable future and maybe lowering with whitelines (0.8”) drop.
I’ll probably run 245/ 40 / R18s as I don’t want rubbing. Anyone running a similar fitment with or without lowering?
Thanks in advance.
JayDiem
Tyler
Colorado
2018 FK8, 2007 Ram 1500, 2000 CRV
255 35 18s on +36 wheels with stock suspension, Trunk is probably weighted down just a little. I feel like a small drop like .8 would be fine.
Honda Civic 10th gen Anyone running 18 x 9.5 +35? 1614991495578
KingOfBrussels
DC burbs
'20 Si sedan
The pic above is a Type-R. On an Si, 18x9.5 +35 will poke past the fenders and a 245 tire will have a decent amount of stretch. Unless you're specifically going for a poke + stretch look (which I personally hate but to each their own) you want +45 offset to be flush, and a 255 or 265 tire to not be stretched.
EkSean
Sean
2019 PWP FC1
Mine are 18x9 +35 so I can imagine they might stick out a little more. Also on 245/40/18
Honda Civic 10th gen Anyone running 18 x 9.5 +35? EE71B640-C039-4A89-AE42-2B61287B3E21
Honda Civic 10th gen Anyone running 18 x 9.5 +35? 8D722C70-5ABD-47A8-AA0D-2D4A4019877E
Honda Civic 10th gen Anyone running 18 x 9.5 +35? F7A1597C-CABC-42E5-98B9-AA67612563C2
Chubs77
Chubs77
Ali
2020 Civic Si
That’s true, I’ve seen the fitment of the rims I want but on the coupe model. That’s why I’m not sure if it’ll be different on the sedan.
Chubs77
Chubs77
Ali
2020 Civic Si
That’s a dope setup. What are those rims?
arpypat
Civic
That's a pretty aggressive setup you're looking at! 34mm more poke than the OEM wheels. You would probably rub at stock height on dips and with passengers if you went with 245/40.
You could probably eliminate any rubbing with some minor fender work if you were dead set on those specs and wanted to lower your car.
FYI, there's a whole subforum for wheel/tires and a thread dedicated for aggressive fitments. You could scroll through to find similar fitments.
https://www.civicx.com/forum/threads/aggressive-wheel-fitment-thread.26817/
