Itll depend on the 255. My 255 Federals are wider than my 265 yoks, no stretch on either tire!Cool. I was going to go with 265 for the squared look. 255 would have a little stretch.
Swift springs.Are you on swifts or coilovers? What's your camber setting?
Damn I shoulda went with 275… didn’t think it would clear on stock height so I went 255 but don’t like the slight stretch lol. Gonna see if the shop will swap em out since I haven’t even put em on the car.Ran 275/35/18 square setup on 18x9.5+45 wheels. No issues even lowered on eibach springs and tracking it.
Yah, you're good. I ran 275 RSRR which run about 278mm wide. When suspension compressed and wheel tucks, you have about 5 microns of clearance. Never, ever rubbed.Damn I shoulda went with 275… didn’t think it would clear on stock height so I went 255 but don’t like the slight stretch lol. Gonna see if the shop will swap em out since I haven’t even put em on the car.
you will need to modify the front fender tab but then you’re fineCan anyone confirm any rubbing with
275/35r18 re71r, with et45
On spring either
1) swift or
2) Spoon.
Thank you all.
its this one right by the side marker. Remove screw, tuck fender liner under the metal, then heat it up and bend it upwards. No more rubbing.What does this front fender tab look like?
