ppawlows
- Jan 27, 2016
- 3
- 16
- 7
- Ontario, Canada
- 2015 GTI, 2016 LX 6MT
If so, what brand and please post pictures.
The difference is to be rated for X lbs of towing the brakes and transmission must be able to handle a full passenger load + X. Having said that I agree that it probably can handle a small trailer with no issues but since it would make zero difference in sales, Honda just says no towing.Also interested. Not for towing, but for bikes. I feel like it's much easier and economical fuel wise to use a hitch mounted bike rack.
I think it's a US thing. Lots of US cars aren't rated for towing, but the Canadian version is rated. A small trailer for hauling appliances or large items would be fine. I mean put 3 full size adults in the cabin and you're talking 500 lbs. What difference is that 500 lb. compared to 500lb. worth of trailer? Still have to accelerate and stop 500 lb.
What class/size receiver are you planning on putting on? I assume that a 2" box could stand torque from a couple of swaying bikes better, but since the Yakima is 1-1/4" and only uses and adaptor for 2", I guess the rack is the limiting factor.I have a Curt Mfg. model on order. It will arrive shortly but will wait until winter has passed for good before installing.
I spoke to my dealer about it. They know me quite well. My only desire for the hitch is to use a 2 bike rack (Yakima Ridgeback 2). I will not be towing anything per say. The two bikes I will haul around total just over 40 pounds.
True. I just remember my 2010 Fit wasn't rated, but the Canadian model was. Not sure if there were any differences.The difference is to be rated for X lbs of towing the brakes and transmission must be able to handle a full passenger load + X. Having said that I agree that it probably can handle a small trailer with no issues but since it would make zero difference in sales, Honda just says no towing.
It's a 1 1/4" (Class-1) hitch as is the Yakima rack. Only carrying two very light weight road bikes.What class/size receiver are you planning on putting on? I assume that a 2" box could stand torque from a couple of swaying bikes better, but since the Yakima is 1-1/4" and only uses and adaptor for 2", I guess the rack is the limiting factor.
Given the ubiquity of hitch mount accessories, the presence of a hitch on a car certainly doesn't mean that it was used for towing. Now, if you had a light plug, ball, and extended mirrors...
I think this statement is relevant to the cvt, only. I have a LX 2.0 6MT and do not see towing being a problem. Most passenger cars are rated for towing between 1500-2000 lbs, this includes Toyota echo.The owners manual clearly states that the Honda Civic is not rated for towing. Put on a trailer hitch and kiss your warranty goodbye.
Go to page 395:
"Your vehicle is not designed to tow a trailer. Attempting to do so can void your warranties."
I spoke to my dealer about it. They know me quite well. My only desire for the hitch is to use a 2 bike rack (Yakima Ridgeback 2). I will not be towing anything per say. The two bikes I will haul around total just over 40 pounds. My dealer had no concern about my use case...
I also believe there are lots of replies to threads about don't do this or don't do that or your warranty will be void. There is that potential but I believe it is limited to the extent that the modification potentially caused damage to... in this case I guess that system would be the powertrain assuming what you were towing placed undue stress or hardship upon it. It would not void the complete warranty to the vehicle.
I have also found it helpful to just speak with my Honda Service Manager. Any modification I have discussed has not been and issue and he openly stated it would not impact the vehicle's warranty.... your mileage will vary.
Yes the only hitch currently available does requires holes to be drilled at the back of the frame.Do you have to drill holes in the frame?
etrailer.com sells one where drilling is not required.Yes the only hitch currently available does requires holes to be drilled at the back of the frame.
https://www.curtmfg.com/masterlibrary/116043/installsheet/CM_116043_INS.PDF
I am still mixed about how I feel about drilling holes, but my neighbor who owns a body shop would install it and will immediately seal the area with undercoating.
