Anyone have LCA for the SI?
incutebus
K
FR-S, 21 Mk5 3.0 Supra, Lexus F-Sport
Running an aggressive wheel and need some options for camber in the rear that works with ADS. Anyone know if SPC / Truhart works with them?
@360glitch
boibuddha
Vancouver
2018 Civic Si
I think you mean rear Upper Control Arm.
I put in the SPC camber arms because these civics gain way too much camber from my subtle drop (1 inch).
Without the camber arms, the 1 inch drop = ~-1.6 degrees camber.
I made extended my arm about 1/2 inch longer than the OEM arm, that put my camber at ~-0.5 degrees.
There is plenty of adjustment on the SPC arms.
I do not see why the other camber arms would not work either.
If you plan on doing this yourself, I hope you have small hands; the driver side is more difficult due to the fuel tank lines.
You'll probably need an offset wrench as well.
I bought these myself, http://www.canadiantire.ca/en/pdp/maximum-offset-box-end-wrench-set-metric-7-pc-0588631p.html#srp
Figured I might as well get new tools since I'm saving money on labor anyways.
BTW, I have a 2018 Si myself.
The SPC arms are good to go. It's a tight fit like @boibuddha said. I didn't use an offset wrench but that may be helpful.
kstawowczyk
Kyle
Pittsburgh
2018 Civic Si Coupe
I picked up at set of Konig Ampliforms that have +35 offset. The stock wheels have +50, which makes these wheels stick out a tad further than stock. I'm low key freaking out now because I'm noticing negative camber that appears to be getting worse. And I'm afraid I'm ruining my suspension. I'm gonna grab the SPC arms for the rear, but should I get front as well? I have a 2018 Si.
@360glitch
L8apex
Southern Cali
2018 SGP Sport
