Anyone else have issues with tunerview on their head unit disconnecting?
Honda_RacerX
2019 Si
  • Thread starter
  • Banned
  • #1
I did the Honda hack and installed tunerview a few weeks ago. My issue is that it keeps disconnecting. It will stay connected for about 20 to 30 seconds then disconnect and freeze, then reconnect, then disconnect, etc. Its been like that since I installed it.
When I use the app on my phone I do not encounter this problem as it stays connected.
When I had Hondata, their app was flawless with Honda Hack. With Tunerview, it simply won't connect or stay connected at all. Thankfully, I have the V2 and use that instead.
86salmon
It's Hedley, Hedley Lamarr!
Chucktown, SC
Issues all of the time on my phone. Kindle fire hooks up pretty well
EdwarDallas
Edward
Dallas, Texas
2020 Civic Si
Mine (In my 2020 Civic Si Sedan) has an issue with initial connection where I have to unplug and then replug it in for it to be detected by Bluetooth. I usually do this right after I start my car so I don't have to fiddle with it again. But I feel each time it just makes the K-tuner unit a little less likely to connect well the next time or it degrades it fitment-wise.
If I switch to my LaneWatch camera and then back, or out of TuneView for anything else (Change the radio station, use Pandora or Waze app--whatever else), often times it does not reconnect or stay connected in the background. Then I have to unplug it and replug it again WHILE DRIVING for Bluetooth to detect it and usually I have to swipe and have it re-detect the Ktuner unit.
It's a Pain In The Ass.
Frustrating.
It should maintain it's Bluetooth connection in the background, I think.
Edward
JT Si
Place
Car
Yep, me too. Very aggravated. I've minimized the effect by tweaking the Bluetooth retry delay and count but it still frequently continuously reconnects. Also frequently it will stop reading from the ktuner.
joshhjackson2112
Josh
Raleigh, North Carolina
18' SI
My tuner view freezes up too. Sometimes when it connects, all the gauges read 0. I can usually pull the menu from the left of the screen to press connect. Then I will have to scan for device. Select the ktuner Bluetooth when it pops up and hope it connects. I often have to do this several times before it gets right.
JT Si
Place
Car
This, too. If I'm lucky, turning the lanewatch camera on and off will trigger it to connect without my having to fumble around with the headunit but sometimes it's just not enough.
I wish there was a better, more reliable option for an app. I don't want to keep a phone, tablet, or ktuner v2 in the car to add a theft risk.
Aguirre129
Cristian
NC
2018 Honda Civic Si
Mine does on a rare occasion. If you have Honda Hack (cant remember if you have to pay for the pro) you can map your buttons to switch to different apps on your screen. I have my up arrow set to Viper4Android and my bottom to TunerView. When it freezes I simply click on my up to change apps and then down to change back to Tunerview. This makes it reconnect without having to disconnect the device from the OBD2 port or having to mess with the screen while I am driving.
