JudgeCrater
- Jan 25, 2016
- 0
- 48
- 31
- GA
- Civic, Ridgeline, Accord
Never any drips or burps with my Touring. Always cleanly unhooks.
I do this, I put paper towel right under the nozzle so if it does leak/overspill, it'll be on the paper towel.One solution is to put paper towels and Clorox wipes in your car. Finish gas, wipe, then disinfect.
Same with my Touring. No problems at all refueling.Never any drips or burps with my Touring. Always cleanly unhooks.
I just bought a 2018 civic sport and filled the first tank. What a surprise that it wasnt obvious and intuitive how to remove the gas pump. (If it aint broke, dont fix it... really Honda? you had to make a gas cap difficult to use?). I was lucky that after pushing/pulling/prodding and finally lifting, it released. There should be a well defined brief on how to remove the pump, should/when it gets stuck. Is it: Lift it almost vertical before attempting to pull it out?For those that have had the gas nozzle get stuck, any tips on getting it removed?
I had mine repaired 4 days after getting the car. The day after I filled up the tank the first time I got emission system issue on the dash so I took it to dealer and they told me the capless thing was broken... I was joking around with my family that they gave me a shitty one because I didn't want to take the additional warrantyPersonally I don't like the cap less tank. IMHO this an added point of failure with practically no benefit. I think Honda will be repairing a lot of these in a few years. We've all been removing gas caps for years, not exactly a difficult or time consuming task. If a gas cap fails (never happened to me yet), it's easy to replace. Anyway, I never lock the hose on and when I'm getting close to full, I back off the trigger a bit. Make sure the nozzle is fully inserted. You also definitely need to wait 10 seconds before removing the nozzle (I know that's not the OP's problem). Also one response indicates they always over flow the tank to get a correct measurement. You should never do this. All car manufacturers instruct you not to top up and only I'll to shut off. If you let it set off automatically then stop, your measurement will be so consistent it does't matter.
So I've been living with this for more than a year now. May be time to take it to the dealer and replace something. Looks like the leak is only an issue with some cars. And yes, I didn't say some users, because I have tried every possible way to fill in the gas without a leak over this one year period. No, I am not trying to remove the nozzle before the 10 secs. It doesn't get to that point as it starts to leak before that most times.HATE this design. I've had to create a new procedure for myself to keep the darn thing from spilling out of the cap. First I guess how many gallons I need because if I fill it up till it stops, a spill is guaranteed. Next I wait 5 seconds, pull the hose out half way, wait 5 seconds, remove. I also hate that when I wash the car or it rains, water and dirt gets in behind the lid, like others, I'm wondering how much of that makes it into the cap.
Side note, I also have recently changed my habits of inserting the hose into the car before running my card and selecting my fuel grade.... Used to do that first but some little B word thought it would be funny to lock the pump handle back last week. Removed it after selecting fuel grade and it started spraying all over my car..... Only 10 minutes after washing it ....... Sigh, I hate people.
Also: https://static.nhtsa.gov/odi/tsbs/2016/MC-10086567-2280.pdfSo I've been living with this for more than a year now. May be time to take it to the dealer and replace something. Looks like the leak is only an issue with some cars. And yes, I didn't say some users, because I have tried every possible way to fill in the gas without a leak over this one year period. No, I am not trying to remove the nozzle before the 10 secs. It doesn't get to that point as it starts to leak before that most times.
