Any ideas? Cyclic "Purr" accompanying Direct Injection ticking
Suhrcooper
Cooper
Blacksburg, VA
2019 Civic Type R CW
Hi all, I have been noticing this new sound coming from what sounds like the engine. The best way I can describe it is as a cyclic purr that happens while idling and while driving. The duration and "wavelength" fluctuate. I notice it the worst when I have just pulled in after driving and let it idle in the parking lot. Very audible from inside the cabin. I have attached a video to hopefully help out. The last 10 seconds of the video provide the best example
afranzen2113
2006 civic
I just noticed mine doing this too. 2019 with 4069 miles.
CDNTyper
Travis
Orillia Ontario Canada
2018 FK8 1999 turbo EK
That’s strange. These motors are noisy with the direct injection. Is it worse with fan or Ac on? Engine cold or warm? Sounds almost like something vibrating against plastic but hard to hear
alpinefd
Walnut
2019 Civic Type-R
mine is making that same fast ticking buzzing noise, 150miles 2019 CTR.
it appear to get louder with quick throttle inputs.
anyone else have the same issue?
alpinefd
Walnut
2019 Civic Type-R
has any of you taken this to the dealer? did they have any solution?
IronFusion
Fred
Philadelphia, PA
2017 Civic Coupe EX-L
Believe the
That ticking is not an issue. It happens on the 1.5L too. Believe it's injector/tappet sounds.
The OP's sound is interesting--sounds like exhaust pipe vibration or pumping sound. You could check the clearance of the front pipe and engine.
If you get the car up to temp and drive around when it is warm-ish outside, no climate control on whatsoever, does it still make the sound?
BogdanM
Bogdan
Romania
2018 Civic Sport Plus 1.5 MT
The ticking is clearly the injectors working. Direct injection system is loud, both the high pressure pump and the injectors, as the sistem works as a much higher pressure (~200 bar).
omar0123
Omar
Puerto Rico
2019 type r
These honda DI engines are quiet next to other brand engines check out hyundai those sound crazy loud thats the nature of the direct injection engine
NMEDRAN7
nelson
jeep wrangler 2003 SE, Honda Civic Type R 2019 RR
Anything like this?
