I would take it into a dealer and ask them to fill it up/write a ticket on it if you can, because then it's documented in the system. It may have just been low from the factory on accident. If you do top it up yourself, check it periodically for a level change.
On the 8th gens it was 60k if I remember correctly. They recommended a coolant flush and transmission fluid change at that point.how often to you refill your antifreeze fluid?
Other car in the family, a Corolla 10 year old, I' never had or change antifreeze.Any liquid tends to evaporate a little. I fill mine about one cup a year with the blue Honda antifreeze. It could be a bit less than a cup.
I'm happy for you.Other car in the family, a Corolla 10 year old, I' never had or change antifreeze.
Same on all our cars we had overs years.
Yes and can make radiator to rust and loose it anti-freeze and coolant propriety . Nothing this happened.I'm happy for you.
Antifreeze in the long run looses his ability to lubricate the water pump.
You can add Water Pump Lubricant to your anti-freeze.I'm happy for you.
I guess you could, but for the price and times it takes to drain and refill with new anti-freeze, I would go with new anti-freeze.You can add Water Pump Lubricant to your anti-freeze.
It is not a question of price and time, No need to do that .I guess you could, but for the price and times it takes to drain and refill with new anti-freeze, I would go with new anti-freeze.
I thought you said that you were always doing what Honda recommends. Look in your user manual at page 487 item 5. Replace coolantIt is not a question of price and time, No need to do that .
I just drop few oz of small can in the overflow tank , few minutes, few $
