kshawn
- Matthew
- Apr 23, 2016
- 25
- 2,602
- 2,796
- Maine
- Website
- www.instagram.com
- 2017 Civic SI
I feel this should be a "no shit" kind of thing. Would anyone here build a D/B/K series and run nearly 30 psi without building the motor and expect it to last? Even the stock boost is pretty high. When people ask me how much boost my tiny little 1.5 liter engine runs, they're always blown away.if running boost above 25 to 27 psi, the engines internals should be built with stronger components
Stock I rarely saw more than 14 psi, and that was going WOT in 4th gear on a steep hill...I feel this should be a "no shit" kind of thing. Would anyone here build a D/B/K series and run nearly 30 psi without building the motor and expect it to last? Even the stock boost is pretty high. When people ask me how much boost my tiny little 1.5 liter engine runs, they're always blown away.
I think they need that higher psi because Honda chose to use a tiny turbo (because it spools faster). Other cars with bigger turbos/engines don't require as much boost.Even the stock boost is pretty high. When people ask me how much boost my tiny little 1.5 liter engine runs, they're always blown away.
I think the WRX's max boost is 15 psi....I think they need that higher psi because Honda chose to use a tiny turbo (because it spools faster). Other cars with bigger turbos/engines don't require as much boost.
I think I've seen 20psi on my '17 WRX and regularly see 18-19psi in stock form. With the MAP stage 1 tune I saw ~22psi. This is all at sea level fwiw.I think the WRX's max boost is 15 psi....
Thanks for correcting. Since they have a bigger turbo I heard they don't need as much boost, I read somewhere they peak at 15 PSI. You would know better than meI think I've seen 20psi on my '17 WRX and regularly see 18-19psi in stock form. With the MAP stage 1 tune I saw ~22psi. This is all at sea level fwiw.
Actually...Thanks for correcting. Since they have a bigger turbo I heard they don't need as much boost, I read somewhere they peak at 15 PSI. You would know better than me
