Another knock thread...
BlackbettyFk_7
Bangor Maine
2018 hatchback sport
Ok so I'm very new two tuning. I'm running hondata + 6 PSI tune. And I never had this problem before. But every once in awhile I get a knock or two or three logged. So my knock control goes up from 54.49 to about 58.20 afterwards. But usually it's sits steady at 54.49. is this something to be concerned about? What is the perfect number knock control is supposed to sit at? Any help is appreciated!
Knock control is going to move around but 58.2 is nothing to be worried about. Don't bother monitoring knock count if you are looking for actual knock, it is a misfire counter and an increment here or there is very normal.
BlackbettyFk_7
BlackbettyFk_7
Bangor Maine
The thing I'm worried about is that it never did it before. This just started happening a couple days ago. Usually k control would sit at 54.49 solid all the time. Just drove home now and the harder I pushed it. Not wot but accelerating, k control went down to 54.69
stevessvt
Steve
Lake Worth
2020 Modern Steel Metallic Civic Si
Bad batch of gas?
BlackbettyFk_7
BlackbettyFk_7
Bangor Maine
That's what I thought but filled up several times in the past week. Still the same
With Hondata, the lowest knock control you will see is .54 and generally you need to use 93 to see that.
.58 is absolutely normal and fine and in no way indicates a bad batch of gas. Knock Control fluctuates a bit depending on load and temps and other factors... all normal.
joshhjackson2112
Josh
Raleigh, North Carolina
18' SI
My knock control usually sits right at .49 but lately it has bee. Actually going lower to like .46. Been on TSP stage 1 for over a year and this is first time. Guessing it's okay....
BlackbettyFk_7
BlackbettyFk_7
Bangor Maine
.58 is absolutely normal and fine and in no way indicates a bad batch of gas. K. Control fluctuates a bit depending on load and temps and other factors... all normal.
That's all I run is shell 93. This is the only time I waited to change the oil for a longer period too. Went about 4500 before it got changed. That matter any?
BlackbettyFk_7
BlackbettyFk_7
Bangor Maine
When you say .49 does that mean 54.49?
Trust me on this...
Don't sweat it. Your car is operating perfectly. Also keep in mind with a base 1.5T like yours, K. Control will rise quite a bit anytime you go over 5000 rpm. It's there to protect the engine. On the other hand, the Si does not exhibit this behavior.
BlackbettyFk_7
BlackbettyFk_7
Bangor Maine
Trust me on this...
This is why I wish they had the si in a hatch lol. Thanks for helping put my mind to rest
Dwight
Delon
Usa
Honda
Does this happens when your flooring the car or just normal driving?
