Another Coolant question
Chaz517
CT
2019 Civic Si
Honda Civic 10th gen Another Coolant question 1000021155
Is this ok to use ? Thanks all!
Chaz517
CT
2019 Civic Si
OEM is formulated to the manufactures specs. A lot of part in an engine are coolant sensitive. Why mess around with something else?
Ok, so what should I get mate? Honda formula?
Hotwater84
Brad
KCMO (earth)
spotify.link
21 1.5L civic sport hatchback
You can use whatever you like as long as it meets spec for the vehicle. I use Amsoil coolant with their dominator coolant boost.
Austin
Chicago IL
www.wunderladenracing.com
2018 FK7
Zerex's blue coolant will work fine in your car, it is basically the same as the Honda Type 2 coolant that was put in your car from the factory. If sticking with OEM fluid helps you sleep better it's not expensive to get from a dealer. Both will be problem free.
Civic Disobedience
Todd
Omaha, NE
2017 FK7 6MT (Hatch Sport)
For my radiator upgrade last weekend, I went with genuine Honda coolant. It's about $25/gallon. I've used Zerex with several of my Hondas without concern, but the closest Honda dealership is 3 minutes from my house. Plus, I never lavished this much attention on my previous Civics, CR-Vs, and the Fit.
slowbrainfc1
Thomas
2019 Civic SI
Just remember if you live in warmer climates you should run a 60/40 ratio of water/coolant to keep temps down
Chilly613
Southern California
2016 Civic EXL > 2023 Civic Sport Touring 6MT
I'll usually use either Zerex or Peak, have had zero issues with either one. I recently used Peak when I drained my coolant to change out my thermostat and radiator hoses.
CMarks
Connor
NJ
2018 Honda Civic Hatchback EX
I got this, haven't changed it yet. Does anybody know how many Gallons/Liters come out for a drain and fill? I have 2 gallons aka 7.56 Liters. And my pan holds 11 quarts.
Honda Civic 10th gen Another Coolant question IMG_2345
Civic Disobedience
Todd
Omaha, NE
I never had any problems running hot until I was tracking my FK7 for more than 20 minutes. The ECU started cutting the throttle, and my coolant temp was around 220 F. I was running Zerex coolant with a stock radiator, and it was about 80 F ambient temperature. That's when I decided to upgrade my radiator.
I could see an argument for adjusting ratios in a much warmer climate zone, where it rarely gets below freezing. We see temps temps from over 100 to -25 F in Nebraska. I don't want to mess around with ratios.
Civic Disobedience
Todd
Omaha, NE
It's about a gallon with the 1.5T. When I flushed the OEM radiator a couple years ago, I don't think I got a whole gallon out. This time, with a radiator swap, I've put in exactly a gallon.
