EnjoyDriving
- Sep 3, 2018
- 55
- 745
- 218
- Minnesota
- 2018 CW FK8
255/35 would they rub?
I thought about Nitto Gen's for the exact oem fitment but couldnt find anything on the web about snow performance so I assume ot would be poor. Not much reviews on them compare to DWS06 but need to get them in a size 35 instead of oem size 30.
Did you end up running the Nitto Neo Gen's in stock size?I've changed my mind, I will be sticking to stock size : 245/30 ; and most likely I will go with Nitto Neo Gen too.
Amazon.com: Nitto Neo Gen All-Season Tire - 245/30R20 90Z: Automotive
I do not recommend the NeoGen. It's OK in the dry. Poor in wet conditions. And if you add cold to the wet conditions it only gets worse. Though it can handle cold-dry conditions with a little loss of traction (it was only OK in dry, warm weather).Did you end up running the Nitto Neo Gen's in stock size?
proxes4plusCan’t find a post on “real” all-season tires for the FK8 stock rims. Have checked tirerack and discount tire. No luck.
Does anyone know if there are “real” all-season tires or are any coming out in the near future. I like to ski and live in New Mexico so road are mostly good in the winter but there can be some snow.
If not, going to go with 18s.
Thanks
what would you recommend stock size for good dry/wet 3 seasons tires? thxI do not recommend the NeoGen. It's OK in the dry. Poor in wet conditions. And if you add cold to the wet conditions it only gets worse. Though it can handle cold-dry conditions with a little loss of traction (it was only OK in dry, warm weather).
I moved away from stock. There really aren't many options in the stock size. If you go a little wider or higher aspect ratio lots of options open up which are far better than the NeoGen.what would you recommend stock size for good dry/wet 3 seasons tires? thx
You can get a 245/35R20 in the Michelin AS4.If you go down to a 235/35, you can go with a Michelin Pilot Sport 4 All Season. My friend is using these on his stock wheels. Surprisingly they have more sidewall and appear wider than the stock 245/30s.
A lot more speedo error, but yeah sure if you don't care that is a good size too.You can get a 245/35R20 in the Michelin AS4.
Page 2 of 3 for Find 245/35R20 Tires | Discount Tire Direct
