alignment results
ivanCivix
Italy
Civic 10th gen 1.5 sport
Hello guys,
i installed the eibach pro kit for my EU hatchback sport and after 1000 km i went to get an alignment.
This is the result:
Front
Toe in 0.2 mm
Camber left -0° 11'
Camber right -0° 48'
Back
Toe in 3.5 mm
Camber left -0° 34'
Camber right -01° 58'
Does it look right for you?
It's not normal left and right camber are so different.
Please give me a feedback, thank you :)
bangminah
2017 Civic Hatchback
Any height adjustments will alter your alignment specs. Depending on the installation, there will be some cross camber which cannot be adjusted without camber plates (front) or camber arms (rear).
ivanCivix
Italy
Thank you for the answers. I know i would need the camber arms to adjust it but if i read that document correctly the values are within the range but there is an huge difference between left and right side.
The document reports:
(Maximum difference between the right and left side: O 0 45 ')
• If the measurement for the rear camber is not within specification, check for bent or damaged suspension components.
Fredo
Fred
Southern Germany
Honda CTR Sport Line
Ciao Ivan,
trovi la differenza in tanti CTR. Anche la mia nuova l'aveva.
Perciò un buon settaggio è sempre molto utile.
Un saluto, Federico
Hondanickx
Belgium
The toe and front camber can be adjusted stock but your camber values are way off .There shouldn't be so much difference between the left and right side.
The rear has more then 1 degree difference left and right....You can adjust the stock front camber by up to 0° 19'.So if you add the 19' of camber to the left side you'll solve the front problem . (0° 30' left and 0° 48' right )
Is the height of the car the same left and right?
ivanCivix
Italy
I will misure it and report, thanks!
