Alignment issues?
Warrengk
Warren
2021 civic
So had a second look at the car via a new dealer. They said everything is within the alignment specs but did show me that both tie rod ends had been extended at some point, I’m guessing to “straighten the steering wheel”. Both ends are even and only about a pinky width of thread is showing. My main question is, will I always deal with the steering wheel being off center during a future alignment and will this “adjusted” tie rod cause any issues down the road. I’m so lost and just need guidance. I don’t trust what Honda is feeding me.
Warrengk
Warren
2021 civic
I'm having the same exact issue when I put my type R steering wheel. I believe I re centered it. Just have to bring it back to the shop for a final check on Tuesday. See what happens
Any update?
Corey2k8g
Corey
Massachusetts
2019 Honda Civic EX
Any update?
My steering wheel was off a tooth. However I still pull to each side. I get torque steer and brake steer. Maybe it's just because of my wheels. But my wheel is straight now. Had the dealer check on it they said all is looking good. So maybe was just my wheel was off
BriteBlue
Illinois
2018 Civic EX-L
Are there any markings on the steering rack to indicate when it is centered?
Warrengk
Warren
2021 civic
I’m guessing mine is too but they keep saying alignment is good but my wheel is slightly off. Idk what to do anymore.
BriteBlue
Illinois
2018 Civic EX-L
If you center the steering wheel, is it the same number of turns to go all the way to right as it is to go all the way to the left? This may be difficult to determine because it will probably be less than 1.5 turns in each direction. But if it takes more turns to go in one direction than the other direction that would seem to indicate the steering wheel is not properly centered on the splines. Maybe put an inclinometer app on your smartphone & duct tape it to the centered steering wheel & compare the angles from all the way in each direction.
