Airbox removal (Acura)
18LX
Ray
West Lafayette
2018 Civic LX
I'm trying to install my intake but cant take out the airbox. I unscrewed the 2 size 10 bolt and the grommet. Is there a bolt on the bottom that I'm missing? I have a 2018 LX.
jakabony
Jake
Pittsburgh PA
www.facebook.com
2017 Honda Civic Si, 2019 Honda CR-V EX-L, 2017 Subaru Forester
Yes there is one bolt underneath that you have to loosen or remove. You can struggle with it or take the front bumper off, which allows full access to everything. It is possible to get the lower air box without removing the bumper. Just takes time and patience.
randomisjustfine
Tadas
Harrisburg, PA
2017 Civic SI
You probably already got it out. If you haven’t and you like to suffer you can take that bottom bolt out from up top in like an hour if you use enough curse words while doing it. You will not be able to see it, there is like < inch gap above it which is all the space you gonna have, ratchet didn’t fit if I remember well.
I was doing PRL install on a parking lot without jacking up the car.
10/10 would recommend.
REBELXSi
Señor Member
'18 Si coupe
Fuck that bottom bolt lol. I couldn't get my fat fingers in there so I ripped the box out like the hulk.
2017 Civic Si Sedan
For what it's worth the 2018 ILX does not share an engine (or intake) with the 2016+ Civic.
