arpypat
Less chance of rubbing on the fender side of the wheel. More chance of rubbing on the suspension side of the wheel.I thought strut pin removal will give more clearance for less rubbing?
Wow. Thats really interesting! Thanks for the info. Was it the tire that was rubbin the suspension side of the wheel then?Less chance of rubbing on the fender side of the wheel. More chance of rubbing on the suspension side of the wheel.
I'm not the one who is running the wheels, so can't answer that. Sorry!Wow. Thats really interesting! Thanks for the info. Was it the tire that was rubbin the suspension side of the wheel then?
My bad dude im blind. I didnt know I was talking to two different people hahahaa.I'm not the one who is running the wheels, so can't answer that. Sorry!
But I'm guessing it was the tire that was rubbing on the suspension. When you go more negative on the camber, you angle the wheel such that the top is closer to the suspension and further from the fender.
If your tire is too wide or if your offset is too high, then you can hit the suspension with too much camber. You also naturally get more negative camber when you lower your car.
So the tire wasn't rubbing at all. Even after I put it back to normal. It was the spring was rubbing on the body up by the mount. So once I put the camber back to normal the noise and rubbing went away. Tires don't rub on the fender at all assuming I'm not low low. I have negative camber in the rear (control arms) as a 'precaution'. 245 40 is the way to go for me. It's comfortable.Wow. Thats really interesting! Thanks for the info. Was it the tire that was rubbin the suspension side of the wheel then?
That is pretty interesting. I think theres thread where a few people have done the front pin removal but they didn't say they experienced any rubbing issues. Are you planning to get the lower adjustable ball joints for more negative camber in the front?So the tire wasn't rubbing at all. Even after I put it back to normal. It was the spring was rubbing on the body up by the mount. So once I put the camber back to normal the noise and rubbing went away. Tires don't rub on the fender at all assuming I'm not low low. I have negative camber in the rear (control arms) as a 'precaution'. 245 40 is the way to go for me. It's comfortable.
So I did buy the SPC ball joints from work and was going to install them once I corrected the strut pin mod. But then I test drove it down a highway strip that I know has big dips and it didn't rub at all. So I returned the ball joints. So no front camber for me is needed at all. Not sure about the rear though. I did it anyway and it looks killer. ?‍That is pretty interesting. I think theres thread where a few people have done the front pin removal but they didn't say they experienced any rubbing issues. Are you planning to get the lower adjustable ball joints for more negative camber in the front?
Do you think your springs would rub if you installed SPC joints?So I did buy the SPC ball joints from work and was going to install them once I corrected the strut pin mod. But then I test drove it down a highway strip that I know has big dips and it didn't rub at all. So I returned the ball joints. So no front camber for me is needed at all. Not sure about the rear though. I did it anyway and it looks killer. ?‍
Looks great man... Notice any rubbing?18x9.5 - 35mm offset
245/40 Nitto NT555 G2
Coilovers going in tomorrow.
Currently on Eibach Pro Springs.
Could you show how much poke there is? I’m assuming no rubbing with no modifications?Thanks!!
No rubbing at all!!!
Looks amazing bro. What are your full specs?
thoughts on my wheel and tire set up. Looking for some feedback. Thanks guys
