Aggressive Wheel Fitment Thread
VtheSi
Nolan
Western PA
2019 Civic Si, 2005 Jeep TJ Sport 6MT, 2002 Jeep KJ
Anybody happen to know what size lugs I need for a 2017 Si?
12 mm - 1.50. If running stock wheels, the lugs are flat bottom, aftermarket wheels are cone. I believe
ydna8433
Andy
Las Vegas
2017 civic si
Ordered some enkei nt03s and was looking at some project kics iconix lugs, not sure which size to get though
SonicBreezerST160
Tom
Everett, WA.
2017 Sonic Gray Pearl ST Hatchback
V the Si already told you. 12x1.50.
Stock wheels lugs are ball seat. Almost all aftermarket wheels are tapered base (60°). Project Kics are very nice, as are Ray's Dura lugs, forged aluminum, or Work.
VtheSi
Nolan
Western PA
will a 18x9.5 +39 with a 255/35 tire work on eibach sportlines?
I am currently running 18x9.5 +38 wrapped in 245/40 on sportlines. Absolutley no rubbing. Not sure about 255/35.
rr1443
2017 Civic Si Sedan
anyone running 18x10+40? TE37, CE28, ZE40 etc or 18x9.5+30/31 TE37/ZE40
TIA
disgraced.fk8
IG: @break_ya_neck_fk7
Drew
Rochester, NY
2021 Boost Blue Type R
57dr 18x9.5 +38
Indy500 255/35
Skunk2 springs
Have had a super hard time finding 18x9.5 +38 on a non-Type R since the fender flares are smaller on ours. How flush with fender is it? Looks pretty on point. No rub? I am not dropping as low as the skunk2, if at all... my driveway is a 30 degree incline. I would imagine this setup is ok stock but there is an extra inch of wheel inside the wheel well compared to an 18x8.5 which would be my second choice, so I'd like to be sure
vandalSI
Nick
kansas city
2017 civic Si sedan
Sits pretty flush. I bent the tabs on the front fenders. Havent heard any rubbing or seen any signs of it. Looks great imo. If you are staying at stock height, you could go 265 and be ok.
Honda Civic 10th gen Aggressive Wheel Fitment Thread 20200722_203452
cocoroos
NYC
2017 Civic Sport
Switched up my suspension setup. I was previously on H&R springs & Bavar Racing BV02 (18 x 9.5, +35mm).
Now I'm on Function & Form Type II coilovers and Volk TE037s (18 x 9.5", +38mm). Factory sport trim tires (Conti 235/40/18). Function & Form sway bar end links and SPC rear camber arms.
Surprisingly, zero rub, even with steering wheel at full lock. Rear fenders are NOT rolled. I think that when I move up to 245 width tires, I'll need to either roll rear fenders or run more negative camber. Just drove 2k miles on this setup over the weekend, moving from LA to Chicago!
Here it is with the weight of everything I own loaded into it:
Honda Civic 10th gen Aggressive Wheel Fitment Thread IMG_8388
Blue18SI
Ryan
Jacksonville N.C.
2018 si sedan, 1989 crx hf
Anyone running SI specific sportlines with 245/40 on an 18x9.5 +40 wheel? I need tires soon and I’m wanting to run either 245/40 or 255/35. Need to know if I’ll run into rubbing issues. Pic of my car for reference. Currently on factory 235/40
Honda Civic 10th gen Aggressive Wheel Fitment Thread 3FD13991-EBF5-4312-B421-B3BB17EF04C9
SonicBreezerST160
Tom
Everett, WA.
Yes, I'm currently running that setup. I've rolled my rear fenders almost flat, which allowed me to take out a lot of the negative rear camber. Was -2.7/-2.9, now is -.9 on both sides. I have the Godspeed adjustable rear camber arms. You will run into rubbing with the 245's, unless you do the above. 18x9.5", 45mm you can get away with it without the fender roll.
Blue18SI
Ryan
Jacksonville N.C.
Good to know. I have the spc rear arms but I just set everything to factory spec. I’ll probably have to do the fender tab mod since mine is an 18’
TSI
MA
17 Civic Si
The wheels are Rays Gramlights 57DR 18/9.5 +38 offset wrapped in 265’s/35/18 continental DWS06 and I’m lowered on D2 springs, I was rubbing a lot until I folded tabs, it still rubs but not as much depending on the dips.
Honda Civic 10th gen Aggressive Wheel Fitment Thread 9C2CE746-B45A-4A47-8A20-ABF2305B0BD2
Honda Civic 10th gen Aggressive Wheel Fitment Thread 1AD7D094-5036-4E7A-B10E-2F693A3B3791
Honda Civic 10th gen Aggressive Wheel Fitment Thread 8BAE8FDC-A4B0-4839-B09E-9E6848BF530E
Honda Civic 10th gen Aggressive Wheel Fitment Thread D13E0AD0-E83E-44E5-A258-8315151558AD
Honda Civic 10th gen Aggressive Wheel Fitment Thread 47492D07-44A9-49D3-B9A3-56E3313CD9C6
Honda Civic 10th gen Aggressive Wheel Fitment Thread 5C295435-A24B-4385-A168-C418AB139796
Honda Civic 10th gen Aggressive Wheel Fitment Thread C5554A57-A1A8-46BC-9822-BD8892D1804F
