Aftermarket Seats and SRS
Matt Noke
Matt Noke
Matt
Roanoke, Va
2017 Civic Si
As Matt stated, they are bolted to the stock rail with (2) 10mm bolts if memory serves. Looking at how they were attached couldn’t quite tell how they detected weight apart from just doing that, so they may still function when attached. I have mine actually connected to the Bride rails versus just having them under the seat.
Do you by chance have pictures of how you attached the sensors to your rails? Every now and then my girlfriend,daughter, or a friend will hop in the car for a ride and it would be nice to know their airbags would deploy if we were to get into an accident. Did you use washers or some kind of a shim to level everything off?
System Motorsports
Thomson
CivicX Basic Sponsor
Thomson
Hayward
FK8 Civic Type R
Matt Noke
Matt Noke
Matt
Roanoke, Va
2017 Civic Si
Gonna try to put my new seat in tomorrow when my seat rails arrive.
If there's anything I should know let me know please.
Im a noob so wish me luck
Good luck, Love the seat you chose!
Great choice in seat selection! Share some pictures when installed
rr1443
2017 Civic Si Sedan
anyone using cipher harness bar? fkx harness bar? any other harness bar for sedans? thanks
Matt Noke
Matt Noke
Matt
Roanoke, Va
2017 Civic Si
do you have pictures of where it mounts on the pillar? did you have to cut the plastic? thanks
With the Chipher bar you would have to cut the pillar plastic covers. I left mine off because my seat bolsters needed the room and I also took out my back seat since it would be unsafe to have passengers back there in the event of an accident.
Honda Civic 10th gen Aftermarket Seats and SRS IMG_20200815_070434
swanarg
TheSwanwar
Anwar
Los Angeles, CA
rr1443
2017 Civic Si Sedan
is there a consensus that the 2.2 ohm resistor is necessary not 2.0 ohm? I can't find anywhere that recommends 2.2 ohm for the xgen except for the replies to @555sexydrive whose original post is no longer found. Which ohm rating did you use in the type r?
i can confirm that 2.2 ohm is the correct one. running these with recaro rsge. i ordered the resistors from evasive, lmk if you have any other questions
swanarg
TheSwanwar
Anwar
Los Angeles, CA
thanks for the confirmation, much appreciated!
