Aftermarket Intercooler Survey
TrippyPancakes
2018 Civic Sport (CVT)
Hi everyone,
I have seen a lot of posts from manufacturers about their intercoolers and some discussion about the benefits of intercoolers but I can't say I have seen anywhere that has pinned down people who have installed them thoughts on the parts so consider this an attempt at that. Only question I'm skipping is "do you see colder IATs after install" because I feel like that is a given lol
If you can comment answering the following questions maybe this can be helpful to some people going forward (including myself)
What intercooler are you running?
What charge pipes do you have installed?
Has turbo lag increased/throttle response decreased since install?
Would you recommend the part to the members on this forum?
Is there anything else you would like to say about the intercooler?
WOPSiWOT
South Carolina
2017 Civic Si Sedan
Mishimoto
Stock pipes
Has turbo lag increased/throttle response increased since install?
Not noticeable. That is one reason O kept stock piping on stock turbo. Also saw dyno from @edgeautosport.com showing no significant difference with upgraded piping on stock turbo. Their install video is also very good.
Yes. Good build quality. Good fitment. No complaints. Honestly, though, there are lots of good options at this point. I also did the black finish with no stencil for stealth look.
Not about this IC, but the stock IC is disturbingly small and flimsy feeling, though it is very light. I can’t believe they use it on the turn-key HPD cars.
edgeautosport.com
JP
Denver, CO
2017 Honda Civic Si
What intercooler are you running? Mishimoto
What charge pipes do you have installed? Mishimoto
Has turbo lag increased/throttle response increased since install? No
Would you recommend the part to the members on this forum? Yes
Is there anything else you would like to say about the intercooler? Check out our YouTube channel, we do a full review on it including what happens when you bolt it on without tuning, and then after tuning.
jayy_swish
Jay
PRL V1
PRL piping v1
I don’t feel like it’s that noticeable, plus lower IAT’s are more important. I can live with lag, but again don’t really feel anything
Yes, all PRL products are incredible!
Recommend pairing it with the PRL race CAI
10GenPearlSi
Old Man
Bob
Houston, Tx
2018 Pearl Si
What intercooler are you running? PLM
What charge pipes do you have installed? PLM
Has turbo lag increased/throttle response increased since install? Yes
Would you recommend the part to the members on this forum? Cheap ripoff of PRL, but works.
Is there anything else you would like to say about the intercooler? It went from a worst case of one second lag to two second lag with intercooler pipes. It went back to a one second lag when I installed a downpipe.
FC1Dawn
2018 Civic Si Sedan
27Won FMIC
27Won's included charge pipes.
Stock turbo spools up pretty quick. Even with one of largest charge pipe diameters on the market, 27Won's charge pipes work very well. I don't feel much turbo lag at all, if any. Power delivery is more consistent.
Absolutely.
My IAT2's and knock control are much lower with the 27Won FMIC compared to the OEM FMIC. I did a review on the 27Won FMIC with datalogs: https://www.civicx.com/forum/threads/27won-front-mount-intercooler-review-with-datalogs.47613/
arnoldo
Arnoldo
Jakarta, Indonesia
2019 Honda Civic Hatchback
What intercooler are you running? Rev9 Intercooler
What charge pipes do you have installed? Stock
Has turbo lag increased/throttle response increased since install? No lag
Is there anything else you would like to say about the intercooler? The intercooler performs slightly better than stock during stop and go traffic but performs significantly better in freeway.
TrippyPancakes
Has turbo lag increased/throttle response decreased since install? No
Is there anything else you would like to say about the intercooler? Might be placebo, but the car just feels better to drive after install (no guessing on how much power I will get)
86salmon
It's Hedley, Hedley Lamarr!
Chucktown, SC
What intercooler are you running? PRL V1
What charge pipes do you have installed? PRL
Has turbo lag increased/throttle response decreased since install? Not noticably
Would you recommend the part to the members on this forum? Sure, although mine was on clearance before v2 release
Is there anything else you would like to say about the intercooler? It recovers temps faster and takes much longer to soak
EkSean
Sean
2019 PWP FC1
DEPO Racing
Kit supplied charge piping
Yes
Definitely, especially price point
There was a drop of about 2psi of boost. No power loss though. I actually could feel a difference in the higher rpm ranges. Lower IATs and lower boost pressure will help engine longevity while not sacrificing any power
kytos
Marcos
Madrid - Spain
CIVIC SPORT 1.5t 2017 EUDM
  • What intercooler are you running? Mishimoto for civic 1.5t
  • What charge pipes do you have installed? Mishimoto charge pipes (have had the stock ones for more than a year)
  • Has turbo lag increased/throttle response decreased since install? Yes, but only down low on stock tune/pipes. With TSP stage1 and mishimoto charge pipes there's less lag than everything stock. (yes, mishimoto pipes helped under 3000 RPM and spool consistency)
  • Would you recommend the part to the members on this forum? Definitely yes, though it's expensive, wait for deals.
  • Is there anything else you would like to say about the intercooler? On european models intercooler will touch front bumper bar because it's diferent than USDM models. No modification is necessary, but I recommend covering the top part with 1.5cm thick foam, and cutting some small ledges from the bar reinforcements (it does not affect the chassis at all), to avoid weird occasional squeaking noises. This is not unique to this intercooler, confirmed that it also happens with the PRL intercooler and surely with others in the market.
Jes_si562
Jesse
Long Beach
2018 civic si. 1990 Honda civic w d16z6 swap (sold) 2019 Honda Civic Hatchback sport(wifes)
Injen intercooler
injen piping
Turbo lag increased slight due to piping. Throttle response increased
yes
Biggest air runners on the market. Does a good job on keeping temps down. Requires trimming stock air strout.
FC1Dawn
2018 Civic Si Sedan
Just curious, what are air runners?
ivanCivix
Italy
Civic 10th gen 1.5 sport
What do you think is the reason stock piping increased turbo lag? It should be the opposite in my opinion. Can you explain please? Thanks
