After I changed wheel bearings on my 2016 Honda civic ex all the warning lights are on now and no clue why or how to get rid of them
How to get rid of them
  • Reset it
    Votes: 0 0.0%
  • How to get rid of them
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
Joey Osbourn
Joey
Covington Kentucky
2016 Honda Civic Ex 2.0l 2003 Pontiac Aztec 3.4l
Romeoridgee
Honda Dealer Tech.
Rob
Maryland
19 SPT 17 EX-T 08 LX 21 CRV 12 Acc 14 328I CONV
Bearings were probably installed backwards
TheCanadian
2020 Boost Blue Type R
If it doesn't sound like its going to blow up, just drive it around the block. Unplugging the battery probably put it into a confused mode. Wheel bearings aren't electronic and shouldn't send a signal to anything
Joey Osbourn
Joey Osbourn
Joey
Covington Kentucky
No they was put in the right direction and I did the factory reset and then drove it home and then shut it down and then restarted it and then the warning lights went off and haven't came back on again so I must of did the right thing to reset it and fix it
ManfromRI
RI
17' CW Civic Type R
It does this whenever you disconnect the battery, it needs to re-calibrate all the sensors, usually you just have to drive down the street and key off-on the car and it's good.
charleswrivers
Charles
Kingsland, GA
I assume you would have had to disconnect and reconnect the ABS speed sensor. I’d give the harness a look. Pretty sure it inputs to ABS, VSA and TPS at a minimum.
