Acuity Short Shifter Issue
Taimaishuuyo
San Francisco
2016 WRX
I’ve recently installed an acuity short shifter and have noticed issues going from 2nd to 3rd between 3-4K RPM. I don’t have any issues shifting 2nd to 3rd after 4K RPM. Anybody encounter this issue?
Currently the gate is increased to the max and the throw is set to 3/5. I’ve been running amsoil synchromesh and acuity cable shifter bushings prior with no issues.
Higgo8
Steve
Stoke-on-Trent
2017 FK8 CTR GT
I've had mine fitted now for over a year and had no issues whatsoever!
You sure the cables were locked in place properly on assembly?
haltamer
Essex, UK
FK8 (UK / RHD!)
For one, I'd suggest reaching out to Acuity directly:- In my experience, they're extremely helpful and friendly.
That being said, it's rather strange / I'm not sure how an RPM-linked shifting issue would be down to the shifter assembly - what are the "issues"? Locked out, crunching, etc?
Centripetal
Boston, MA
2006 RSX Type S, 2017 Civic Type R
I just installed the Acuity short shifter (with the same settings as you) and noticed the same thing. However, I think what’s happening is just more noticeable with the Acuity. It seems like its the synchros coming up to speed. If you hold the clutch in for what seems like a long time, it’ll go in. After driving for 30 minutes, it’s seems less noticeable. Consequently, I had ignored it as synchros but your post made me want to take a drive and pay attention to it. Take it for a long drive and see if you notice the same. You might need to take a longer drive (> 30 minutes) because the viscosity of the synchromesh is higher.
Doc_Mello
2019 CBP Si Coupe
I agree. With the full shifter upgrade, it’s a leverage issue, yeah? More leverage + a lack of ‘bite’ on the synchros -> more time needed to ’sync’? As for the 2-3 gear change: must be a torque vector issue, yeah?
(full disclosure: certainly NOT an automotive engineer. Just conjecturing. ?)
Lust
Michael
Bay Area
2019 Champ White Type R
My 2-3 is complete butter when warm. throw setting is at 4, knob height 2, and gate spacing in the middle. I run a thicker fluid (Motul gear 300). I notice that it’s less happy when cold and sometimes crunches. I don’t think it’s a problem at all with the shifter. Try swapping your fluid to GM synchromesh friction modified and adjust your clutch pedal
TypeSiR
On a Twisty Road
1.5T Civic, Fit, MX-5, CTR
Reset everything to their middle settings except shift knob height and fine-tune everything before reinstalling the center console (this will save you a lot of time later):
https://www.civicx.com/forum/threads/what-did-you-do-to-your-type-r-today.13242/page-556#post-754644
Taimaishuuyo
San Francisco
2016 WRX
Good to know I wasn't going crazy. For what it's worth the issue became essentially no longer noticeable with a weighted shift knob. I've also made the following changes to compliment the added weight. I'm running a skunk2 shift knob and it may actually be a little too heavy for my taste.
Shift Lever - 1
Gate - 2
Shift Throw - 4
Honda Civic 10th gen Acuity Short Shifter Issue pdxsXgLEcPy_tJP1OFu0iteSaGo&_nc_ht=scontent-sjc3-1
