Action Clutch Stage 3 W/ Light Weight Flywheel
mandofc3
Mando
Fontana, CA
2018 Honda Civic si coupe
I recently got the first action clutch stage 3 with the light weight flywheel installed by DTtuned in Ontario, ca.
the stock clutch kept slipping with the bolt ons but so far ive done a few pulls and it is a huge difference, I was debating with clutch master fx400 and the stage 3 action but I’ve heard bad things about clutch master especially with there clutch having chatter. So far I’m 540miles I’m with action and I have no chatter in 1st or 2nd gear but a mild chatter in reverse.
I’ll post up some videos of pulls and diggers later on to keep you guys posted on the stage 3.
Honda Civic 10th gen Action Clutch Stage 3 W/ Light Weight Flywheel 74101147-DE09-43DF-BBB8-69D26F69A8E9
Honda Civic 10th gen Action Clutch Stage 3 W/ Light Weight Flywheel 8AD5E837-92D4-41CC-AB69-D87069AFDD49
Honda Civic 10th gen Action Clutch Stage 3 W/ Light Weight Flywheel 5193452E-23B5-4A9A-BE72-7D02193AC7F8
Honda Civic 10th gen Action Clutch Stage 3 W/ Light Weight Flywheel 56DDB846-1286-4161-BA95-B713C819DE32
WingKing76
Embrace the Grind, Because the Grind is Real!!!
CJ
GA
2018 Civic Si
How is the driveability and is the engagement smooth?
mandofc3
mandofc3
Mando
Fontana, CA
The engagement is way different from stock but it is great it engages quick so for the first hundred miles it will feel stiff and you will need to find the best engage point because that’s key or you will be having trouble with first. And driving with it is like stock just 1st and 2nd engage pretty quick.
VooDuuChild
Westsiiiiiiiide
2018 Civic Si, Boosted Street and Track Monster 91 CRX Si.
Did they say the power that clutch is rated for? Does it rev up or down faster with the aluminum flywheel? Thanks!
mandofc3
mandofc3
Mando
Fontana, CA
No they didn’t have what the clutch is rated for but I dyno the car and I’m at 273hp with a conservative tune and the clutch is holding up good. Yeah you can feel the clutch rev up faster
Jes_si562
Jesse
Long Beach
2018 civic si. 1990 Honda civic w d16z6 swap (sold) 2019 Honda Civic Hatchback sport(wifes)
mandofc3
mandofc3
Mando
Fontana, CA
So I’ve had the clutch for 3 months now and mostly daily driving it I’ve done a few pulls and it’s very torque-y because of the light weight flywheel. I only have clutch chatter in 1st gear at slow speeds, no chatter in 2nd it reverse anymore. The petal did soften up about 1000miles in to it and in traffic it’s not so bad. I’ll try to upload some videos tonight
zhendexing
Dee
Chicago
2018 civic si coupe
Any high rpm lockout issues spec has?
WingKing76
CJ
GA
2018 Civic Si
Any update.
