ACT Clutch + Flywheel Review
AsianGuy98
2017 Civic Si Sedan
Anyone have the street kit and also has an upgraded turbo or big turbo kit? If so how is it holding up? Thanks in advance.
CanadiaegeanBlue
Humza
@madchiller has it. 345whp, and 308wtq on E30 using the PRL Big Turbo Kit
Unity Performance
Humza
Toronto, ON | Buffalo, NY
unity-performance.com
Mileage check-in? I'm at 2,500 miles on Blue, 0 issues to report. CDV Delete, KZ CMC Line, and PRL SS Line were all performed/installed during clutch install.
How about everyone else?
We've delivered 4 kits, awaiting delivery on another 6 for Canadian and USA folks :) Wait times have been averaging 2 months due to slower production
https://unity-performance.com/products/act-hd-street-clutch-kit-civic-1-5t
Benster
Ben
Nova Scotia, Canada
2019 Civic HB Sport 6MT
about 5000km on mine maybe more, only SS line for now, waiting on money to get the KZCMC. I got maybe 2 full gear lockout at high RPM(past 5500) high load otherwise you could think it's a stock clutch. Once I do the CMC I'll remove the CDV cause the clutch feels random at times, engaging nicely or abruptly with the same release speed and conditions. Running Ktuner dual tune and haven't had any slip whatsoever.
thejdoner
Jordan
Boca Raton Florida
2020 Honda Civic Si Coupe
Ordered my set on Black Friday. Import Image Racing just delayed it again to mid February. Fvckin nuts. Out of stock on ACT's website as well.
JT Si
Place
Car
9k miles on mine and now using a KZ CMC. For some reason it doesn't work right - if I adjust the pedal up to get good high speed shifting, pedal-to-the-floor locks me out of first gear. If I adjust it so pedal-to-the-floor doesn't lock me out of first gear, I get difficult/poor shifts at speed/higher RPM.
I still have the SS line from the failed sirimoto N1 CMC installed. Maybe I need to swap back to the OEM hard-line and do the PRL SS upgrade. (N1 line is entirely SS, replaces entire OEM hardline).
kytos
Marcos
Madrid - Spain
CIVIC SPORT 1.5t 2017 EUDM
ACT Street disk kit + flywheel installed since Monday, upgraded to KZCMC and custom steel braided line a while ago. Still in the break in period. I am impressed with how smooth and manageable it is, but it provides better response and grips much better.
CocoErupto
Rob
Las Vegas
2020 Civic Si Sedan
I just did the same. I picked up my Si on Saturday. ACT Street Kit w/ Flywheel, kzCMC, PRL SS Clutch Line, and I also had them delete the Clutch Delay Valve. I'm at 250 miles on it so far, still breaking it in. Definitely a better response, catch point isn't so vague, and that clamping action, wow. I love it.
Unity Performance
Humza
Have you performed a CDV Delete? Do try that before replacing the line, and if so then try replacing for a PRL SS Braided Line.
Also, which throw out bearing did you use? We've seen silver use OE Honda, some use ACT; we used the latter
kytos
Marcos
Madrid - Spain
I haven't removed the CDV and used the ACT throw out bearing. Will update here once I finish the break in.
JT Si
Place
Car
No delay valve delete, and I used the ACT bearing.
I was thinking about doing the delay valve delete soon as I'm starting to notice it's effect more and more frequently.
ChefRyeSi
Ryan
Rhode Island
2018 Civic Si Sedan / 04’ CRV EX 5MT
Hows the how set up? I have an identical setup on the way but am curious if the CDV delete is needed, car is mainly a DD and some minor street racing
Kotaas
Ruben
2019 civic si
My act street only lasted me 4 months 15-20k miles :/ Im assuming I hit the tq rating already since its to the crank. Unfortunately I didn’t take pictures of it since I saw it after I blew my tranny but it was worn pretty bad. Surprised the guy with the big turbo hasn’t said anything about his clutch hopefully it’s solid for you guys.
kytos
Marcos
Madrid - Spain
Quick update. The clutch feels nice, engagement gets a bit softer after a few km. Can't comment on high RPM as hardly ever hange at more than 6000rpm but seems fine. CDV makes engagement less predictable but I think I'll it keep to soften trans shock at medium to high rpm. Low rpm high load seems to make a bit more trans noise due the lack of dual mass but nothing concerning.
Benster
Ben
Nova Scotia, Canada
Not needed but the clutch engagement does feel random at times. I might do the mod myself and see the difference.
