Abs dynamics type R spoiler installation in NJ or Philadelphia
S60doc
Arnold
New Jersey
2018 Honda Civic HB Sport
Hi guys I'm thinking to get ABS dynamics Type R style spoiler for my sport hatch. Since we need drilling I wanna let the professional install it for me. Any recommendations in South Jersey, Central Jersey or Philadelphia area?
I mean I can do it by myself, but
1. I'm living in apartment, no place for doing it
2. Water leaking issue is kinda my concern
thanks
S60doc
S60doc
Arnold
New Jersey
i added silicone to the bottom that meets with the hatch door to keep water out.
Any kinda silicon would be good? Or should I get specific one?
i think I'm gonna do by myself at parking spot ?
vtecr
FK
Eire
FK7 GT-Spec Daily, EP3 Type-R, EP1 Project, EU7 Beater (+ others I care less about...)
They give you a template so the drilling is really easy. It's pretty thin too so you'll be through it quickly.
I'd recommend mounting it on there and confirming that everything is in the right place, then use a urethane adhesive instead of silicone (I use Tiger Seal for these kind of jobs). It'll help to reduce flex that will ultimately loosen the bolts and it'll also prevent vibration. Silicone is great on stationary parts that aren't going to move but this wing will flex relative to the tailgate and the silicone will shrink a little.
gdagreat
g
OC
2020 civic ex hatchback
make sure to have someone helping you.
use loctite on the bolts that go all over the wing, i used the silicone for water and vibrations from my system. bought it at autozone
Honda Civic 10th gen Abs dynamics type R spoiler installation in NJ or Philadelphia 218004D6-59F3-497E-AD37-EAE23E7359C8
S60doc
S60doc
Arnold
New Jersey
Thank you! I watched couple videos on youtube, it's seems not that hard. My concern is Honda's paint already not good, if I got water through those holes I may ended up with rust issues.
let's see what's gonna happen!
@gdagreat thank you I'll check that out!
disgraced.fk8
IG: @break_ya_neck_fk7
Drew
Rochester, NY
2021 Boost Blue Type R
I put 3m mounting tape all on the underside of the base pieces and ran for like 30k miles with no issues. We also got leftover paint from the wing being painted and used that on the holes so they wouldn't rust.
I would go to home depot and find the bag of miscellaneous rubber washers - it's in the plumbing aisle - as they will help in some spots. Also, you will need longer bolts. I can't recall what size exactly but I think it was like 75mm long. The ones they provide are too short if you add any washers.
If you were at the border of PA and NY I'd say I'll do it for like 50 bucks but I'm up in Rochester, there's no way you'd want to drive up lol. I've installed one on a coupe, and then we pulled that off to swap for a GT wing. Mine is now an APR GT wing too I couldn't help myself from upgrading :rofl:
disgraced.fk8
Drew
Rochester, NY
And let me tell you, that 3m tape... I had to literally push so hard I was moving the car all over the place to get that stuff off. Took me like a few minutes with constant pressure from different angles to get the bases off!
I think that was about 95% of the holding force... not sure the bolts even mattered haha.
S60doc
S60doc
Arnold
New Jersey
Thank you guys all! When I have time I'll try to install, let's see what's gonna happen!
i love this forum, I love how people help each others :)
Be safe all!
Phy
TN
Be safe all!
Do a test fit before you do anything to make it "permanent" like 3m tape or waterproofing. I had to adjust the holes to get it to line up and sit flat.
Civic_Andreas
Andreas
Sweden
Honda Civic 1.5 VTEC Turbo Sport Plus -17
S60doc
S60doc
Arnold
New Jersey
Thank you guys, I'm still waiting for shipping when i get the spoiler I'll try to follow your recommendations.
I can't wait ?
datboostedFK7
New Jersey
2017 Civic Sport Hatchback
if you feel uneasy about installing it there's a good body shop in linden vilar auto body ask for pedro he does amazing work he painted my parts on my 8th gen great work
S60doc
S60doc
Arnold
New Jersey
I finally got spoiler today. I'll be installing tomorrow. Wish me luck guys!
