A7 maintenance minder
georgewny
66 Stang / 80 Triumph TR7 Spider
NY
66 Shelby GT350H convertible clone (black n gold), '07 Honda Odyssey EX (blue), '11 BMW 335IX (diamond sapphire black), '14 Mercedes C300 Pearl White, '16 Honda Civic EX w Sensing (rallye red)
Hi folks,
our 2016 Civic EX with only 12200 miles just got a A7 maintenance minder, which I believe means change the brake fluid. Doesn't that seem to be on the low side in mileage to change out the brake fluid. And the brake reservoir fluid was very clear and clean, as one would expect. Also the fluid was at it's full level, meaning that the brake pads are not that worn either.
I can do a brake fluid change, but I don't believe that one would be required at this mileage and shape.
any suggestions?
Civics4Ever
Rally Red EXT
Gene
Illinois
I believe A7 is for tire rotation, B7 is the brake fluid.
georgewny
georgewny
NY
I found this, which lead me to believe that A7 brake fluid related.
If a Maintenance Minder indicator does not appear more than 36 months after the item 7 is reset, change the brake fluid every 3 years.
NOTE:
Honda Civic 10th gen A7 maintenance minder burret0001
Inspect idle speed every 160,000 miles (256,000 km).
Adjust the valves during services A, B, 0, 1, 2, 3, or 9 if they are noisy.
Number
Maintenance Sub Items
Rotate tires, and check tire inflation and condition
Follow the pattern shown in the Owner's Manual.
Replace air cleaner element
If the vehicle is driven primarily in dusty conditions, replace every 15,000 miles (24,000 km).
Replace dust and pollen filter
Honda Civic 10th gen A7 maintenance minder burret0003
Replace filter whenever airflow from the heating and air conditioning system is less than normal.
If the vehicle is driven mostly in urban areas that have high concentrations of soot in the air from industry and from diesel-powered vehicles, replace every 15,000 miles (24,000 km).
Inspect drive belt
Look for cracks and damage, then check the position of drive belt auto-tensioner indicator.
Replace M/T fluid
Honda Civic 10th gen A7 maintenance minder burret0005
Driving in mountainous areas at very low vehicle speeds or trailer towing results in higher transmission temperatures. This requires transmission fluid changes more frequently than recommended by the Maintenance Minder. If the vehicle is regularly driven under these conditions, have the transmission fluid changed every 25,000 miles (40,000 km).
Use Honda MTF.
Capacity: 1.9 L (2.0 US qt)
Replace CVT fluid
Use Honda HCF-2.
NOTE: Using the wrong type of fluid will damage the transmission.
Capacity
1.5 L engine models: 3.7 L (3.9 US qt)
2.0 L engine models: 3.5 L (3.7 US qt)
Replace spark plugs
Inspect valve clearance (cold)
Intake: 0.21-0.25 mm (0.009 in)
Exhaust: 0.25-0.29 mm (0.010-0.011 in)
Replace engine coolant
Use Honda Long Life Antifreeze/Coolant Type 2, and if necessary add Honda Extreme Cold Weather Antifreeze/Coolant Type 2 (concentrate) as needed for prolonged cold temperatures below -22 °F (-30 °C).
Capacity (including reservoir)
1.5 L engine models: 5.1 L (1.35 US gal)
2.0 L engine models: 5.3 L (1.40 US gal)
Replace brake fluid
Use Honda DOT 3 Brake Fluid.
We recommend genuine Honda Brake Fluid.
Check brake fluid level is between upper and lower marks on reservoir.
CE1_nobling
Spring,TX
2016 Honda Civic LX 6sp , 1997 Honda Accord EX Wagon , 2005 Chevy Silverado 2500HD CrewCab 6.0
Honda recommends changing the brake fluid every three years, regardless of mileage.
andromeda
Long Island NY
'04 & '16 Civics
I'm 71 and been maintaining cars since before I drove. Back in the day, no one would dream of changing brake fluid, and to do so would be a major operation or even impossible. Only reason would be contamination or degradation. Just how is that supposed to happen ? Of course Honda and MM are going to say that as CYA. What'd you expect ? I'm currently driving well functioning Civics, an '04 and a '16, and it's never been done on either.
wdrx02
Batman
Civic HB
A7 shows up as oil and brake fluid on the 10 Gen civic. You can find the specifics in the Setting -> System -> Vehicle - Maintenance info. (discovered it today) when I did fill my brake fluid reservoir to max/full. It was on low... weird....
BrandonSmith
The Greatest Country on Earth
2016 Civic EX 2.0L
This thread has been dead for nearly three years.
jdm_mike
Acura Canada
20 FK8 CTR & More
