94 Octane Gas
Pilksdaniel
Daniel
Montreal
Civic Si HFP 2018
Hey Guys,
So I filled my 2018 Si for the first time yesterday, I put in 94 octane. The station also offfered 91 but I opted to go with the 94 instead. Did I make the right choice? Any advice on which premium gas I should run in my Si?
Always happy to hear your responses,
-Daniel
amirza786
A
Northern California
2006 Camry SE V6, 2013 Toyota Sienna LE, 2010 Lexus IS 350 Sport, 2018 Honda Civic Si (SOLD)
I doubt you would be getting a benefit from 94 octane unless you were doing sustained hard driving on a track under high temp conditions where pre-detonation can become an issue. Higher octane gasoline, which is more stable, has no more energy potential than lower octane gasoline. There is no more energy to be had from high octane gasoline, then from low octane gasoline. You are definitely spending more money. From what I know it is not going to hurt your engine, but more your pocketbook. I would stick to 91 which is the recommended octane level. Just my 2 cents
Pilksdaniel
Pilksdaniel
Daniel
Montreal
Civic Si HFP 2018
  • #3
I doubt you would be getting a benefit from 94 octane unless you were doing sustained hard driving on a track under high temp conditions where pre-detonation can become an issue. You are definitely spending more money. From what I know it is not going to hurt your engine, but more your pocketbook. I would stick to 91 which is the recommended octane level. Just my 2 cents
Alright thanks for the advice, the manual says 91 and above not just 91. I do understand your point though.
amirza786
A
Northern California
Like I said, it's not going to hurt your engine, but unless you are on a race track pushing your engine to it's limits, you would not be getting any additional benefits but would be paying the additional cost. For those who track or race and use their daily drivers, they will usually switch to a higher octane, but than switch back for their "normal drive"
racer
Dave
Virginia
2018 Civic Si sedan.
Some states don't offer more than 91, hence the 91 rating honda worked with when designing the motor. As mentioned, it won't hurt your car to run higher octane.
Captaindicki
Ontario
2018 Honda Civic Si Coupe (sold)
Would higher octane levels give better mpg the higher you go in these Sis?
SoCalCivicSI
Car Addict
Jerry
South Carolina Near Spartanburg, formally So Cal
2018 Aegean Blue Civic SI, 2006 2.4 5 Speed EX Accord Sedan, 2007 Red 5 Speed Pontiac Solstice
No.
Also, these modern motors don't have any "pre-ignition" problems. If you use too low an octane the PC knows this and automatically detunes your motor so there won't be any pre-ignition.....you'll have less HP but no pre-ignition.
