9" Aftermarket Android Head Unit (Feature Overview / Installation)
caldersm44
Steve
North Augusta, SC
2018 Civic Sport - 6 Speed
I have a 2019 sport and for the m400 install did you guys connect the mic and antennas it comes with or are the stocks plugs already there to connect ?
The existing radio antenna fits and plugs directly into the back of the radio. You also have a cell antenna and a gps antenna. I plugged them all in, but I use my iPhone with CarPlay for GPS, so really won’t use them. I just put them behind the radio. I like the new mic better. One thing for sure...I am getting 4x more stations on the radio. See below some pics for the antenna connections and mic connections. I took a lot of pics of the install.
caldersm44
Steve
North Augusta, SC
The install went well. The bass is noticeably better with this head unit. The Apple CarPlay sometimes takes a minute to boot up, but I mostly use bluetooth because it just pairs and instantly starts playing. I had to try all of the yellow plugs coming out of the head unit until the correct one turned on the reverse camera when my car was in reverse. I do have the CVT, so not sure how it works with the 6mt. A few negatives are the reverse camera is grainy, it wasn't supplied with the stock antennae connection for the car, the unit lags occasionally, songs cut out occasionally on CarPlay, and the door open alert pops up randomly. Otherwise, it was a great upgrade. Call quality with the supplied mic is good, and still just waiting to install my 12v wires for my underseat subwoofer. Where do people typically run the ground to for subwoofer amplifiers? I am using a custom free launcher because it allows me to customize things to my liking. I haven't tried to run YouTube or streaming Netflix because I don't sit in my car unless I'm driving. The more I play with it, the better I get at navigating it, and figuring out what works best. It's $193 for this version on Aliexpress, which is a great deal, and it got to me in like 2 weeks.
If u want the CarPlay to connect faster....Naldy posted a fix. You find out the IP address u are getting dealt from the radio and set it to manual programmed at that IP....but leave the router address empty. That way it won’t think u are connecting for internet and since it is a fixed IP, it won’t have to wait to negotiate it. Mine is really fast now! And I set the sleep to like 3 days so it boots instantly.
civic model x
Bay area
Civic sport
Appears page 9 has information on tapping into the stock microphone in the car. As opposed of using the supplied mic that you would have to stick somewhere.
If correct I should be able to buy an open end 3.5 cable from Amazon. Using posi taps to tap into the stock wire harness and just plug the 3.5 cable to the navifly.
picture pulled from page 9. I believe that is the stock harness
Tap this to the stock harness and plug other end to unit.
IronFusion
Fred
Philadelphia, PA
2017 Civic Coupe EX-L
TBH I didn't read everything. 69 pages is redic. This just seems like a lot of work for not a lot more oomph.
civic model x
Bay area
Civic sport
Yes a lot of information spread out on this post. Had to dig. But honestly from what I’m reading this is an easy plug and play upgrade. I am just picky about the mic. I rather have it more integrated. But once added you should have the following More options if you have the 5”
Upgrade advantage
9” screen
Android system with downloadable apps
Apple car play
Better audio
Faster than the stock 7” on higher models
WiFi capabilties
Touch screen
More customizations
Maybe I can use hondata on this now
Plus more
I wouldn’t say not a lot of oomph.
IronFusion
Fred
Philadelphia, PA
Upgrade advantage
9” screen
Apple car play
Better audio
WiFi capabilties
Touch screen
More customizations
Plus more
So, having admitted I haven't read most of this... Sell me. I've got $X and have my eyes set on a new grill.
I currently don't use Android Auto, just manually BT pair after my HU (tunerview lite) pairs with KTuner, and have my phone for nav in a mount just below the HU. I stream all my music via BT; source is HQ.
I've used the free Honda Hack.
Just curious what the allure is.
civic model x
Bay area
Civic sport
you already have an ex so not sure if this would benefit you as much as those of us without the 7” screen. Also this stereo may not be plug and play for people who have the built in amp.
caldersm44
Steve
North Augusta, SC
Yes....that is what I see on my PDF.....C22 and C23. That should work. Let me know if it works ok....I might do that....although the new mic sounds much better than that old one...according to my wife.
When you get your radio.....let me know if your reverse camera works or not. If you look at C16...that is the Camera Detect...that is not wired into my harness, but I think it should be. Also....with the 5" display....we do not have a C15....which is the reverse signal. I have asked Navifly for help...and they are sending me a video of how to fix this....but I believe it is a wiring issue. I will try their solution...but if it doesn't work....I am going to try to measure that C16 wire voltage and see if i can get that into the reverse signal of the radio directly.
caldersm44
Steve
North Augusta, SC
I don't see a huge reason, as you already have a touch screen. Naldy...I believe....went from the 7" touch to the new one....he might have more information. From the 5" non-touch...this is a HUGE upgrade....especially with Wireless Carplay. My son used the USB connection to watch a few movie on it this weekend when we travelled...he was so jazzed...! With Netflix....Youtube....much better radio.....and the amp REALLY brings the volume way up from the 5" HU.....I mean it is a HUGE upgrade in sound. It was a no brainer for me.
Having said that....I might struggle....if I had a 7" touch with this upgrade....versus getting a RT-B380 Bullseye Grill. For $399 you get a smoker that goes down to 200 degrees....and a grill that goes up to 700+ degrees.....I would get that grill instead.....just saying. :)
https://www.recteq.com/RT-B380-Bullseye-Wood-Pellet-Grill
naldy
mick
Kansas City
2019 Honda Civic Sport Hatchback
I went from a 5" to this so it was a pretty significant improvement. These units are also way faster than HondaHack. For some background, I went from the stock 5" to a Pioneer 7"(?) to a Joying 9" Android unit and finally to the Navifly 9" Android. I'm just personally a stickler for UI design audio quality and an OEM look. These Android units for me kinda scratch all those itches. But I will say that the built in bluetooth player on these is pretty basic, I almost always use Apple Carplay.
Also still havent figured out how to connect my unit to Tunerview either which kinda sucks, and I'm not entirely sure that I'll be able to do so. But I have a Ktuner V2 so it's not a problem
That being said, these units are amazing for road trips. My gf and I had movies running for our entire 8 hour drive to Colorado last month.
There are definitely little quirks here and there and these units aren't perfect but I've had absolutely no regrets and it's made my experience in the car all that much better
caldersm44
Steve
North Augusta, SC
I went from a 5" to this so it was a pretty significant improvement. These units are also way faster than HondaHack. I'm just personally a stickler for UI design audio quality and an OEM look. These for me kinda scratch all those itches. But I will say that the built in bluetooth player on these is pretty basic, I almost always use Apple Carplay.
Naldy....if you get a chance to snap a pic of your 32 pin connector...car and radio side....would love to get those images. Just to see if this is a software thing or hardware issue with my reverse camera. Thanks man....
civic model x
Bay area
Civic sport
I’ll let you know about the back up camera once I receive the unit. I found a new audio cable I have lying around. If I read page 9 right I should be tapping into the following. Audio cable white would be right positive, red should be left negative, and finally Shielded ground. Knowing this information I believe the mic should be tapped to the factory harness the following way
22 mic white right positive
23 mic red left negative
6 mic Shielded ground
naldy
mick
Kansas City
I'm installing a USB adapter to retain the factory port sometime this week, I'll make sure to take some detailed pictures
This is the USB adapter if anyone needs it. It has a USB-out instead of the proprietary Head Unit connector so these should work universally for any head unit you have
https://www.amazon.com/Bestycar-Fac...ords=toyota+factory+usb&qid=1603119090&sr=8-4
civic model x
Bay area
Civic sport
Thanks for this I didn’t know the factory port was not retained. I would definitely want this option as well.
naldy
mick
Kansas City
It usually is, my unit just came with the wrong cable. And most units from Pioneer or Kenwood for example won't include something like this
