Guess I will just hang out at this firmware for now. Only issue I have is when Maps will speak directions, the volume will reduce and not come full back up until I exit CarPlay. So I can't listen to direction....same for all gps applications.This is my m400 version. Same as yours
That’s odd. I don’t have that issue. On car play it lowers the volume and comes back up. What I do get is maps.me on the android side does not mute to lower volume could be the app I guess. Maybe because I use waze in car play. But waze has been buggy. I always have to close it the first time I start it on apple car play then it works.Guess I will just hang out at this firmware for now. Only issue I have is when Maps will speak directions, the volume will reduce and not come full back up until I exit CarPlay. So I can't listen to direction....same for all gps applications.
Thanks for posting this again. Her phone was set to that, but at some point the unit was set to have its wifi tethering off. I turned that and Bluetooth tethering back on.It is using WiFi to tether......but there is no WiFi antennae....unless it is using the 4G one. I have that pictured below....mine is pushed back and dangling above the bottom console. Also I use a wireless charger that fits perfectly and charges my iPhone pretty quickly.
Make sure that you setup your iPhone IP to be manually connected to the radio....below is the information I believe Naldy posted....this is VERY important for quick and consistent connection. If you can't figure it out....just email me back and I can step you through it. It is 100% better with a fixed IP.
"If you're using an iphone, go into your Settings>Wifi>[Tablet Wifi]. Click the little (i) button then change "Configure IP" to Manual. Copy over The IP Address and Subnet Mask from the previous screen, BUT leave "Router" completely blank. This will make sure your phone doesn't try to connect to the Tablet's wifi for actual internet access"
4G antenna....might be what they use for WiFi....not sure.
My wireless charger....from Amazon....is amazing...and only $17 for two right now
Link -->> Wireless Charger (Square Small)
I placed in the OEM area where the nav trims placed, under the gauge trim. Pull forward and up. Need some good forearm strength. the mic I placed on a blank button.Thanks for posting this again. Her phone was set to that, but at some point the unit was set to have its wifi tethering off. I turned that and Bluetooth tethering back on.
Makes sense that part is the wifi antenna, now that you show it, I remember it. I'll have to open up the unit and place it somewhere ideal.
Hopefully the wifi settings fix the issues. Thanks again!
Hi i have a 2018 hatch sport 6 MT so the reverse camera wont work and i have to tap on wire?. Is it on the start of the thread coz i started reading for 65 sorry.It is plug and play now that we have figured out everything in this thread. Order it and then spend an hour looking through the thread....there are gems for setup in there. If you have a manual 6 speed....then you will need to buy some T-Taps to connect the reverse signal to the radio....it is one wire. Other than that....everything is pretty straight forward....and we can help too.
It's on post 72.....Hi i have a 2018 hatch sport 6 MT so the reverse camera wont work and i have to tap on wire?. Is it on the start of the thread coz i started reading for 65 sorry.
I have two possible connections but neither works...the one that's unplugged here is connected to the unused plug, which I took a pic of as well.Show us your yellow cable connectors. You must have the cam plugged into the wrong connector. These are the plugs I am using and below u can see I what I have plugged in...sort of. LoL. You are missing the 20 pin connector?
That unused plug is used on my car for the cameraI have two possible connections but neither works...the one that's unplugged here is connected to the unused plug, which I took a pic of as well.
Martin,Hi guys, I bought the Mekede 7862 but found out that my Honda Civic HB Sport 2019 (Manual) has an old type of plug?
My Civic comes with the plug on the left and the Mekede has the plug on the right. Any suggestions on some converter I can buy or would I need to cut and tie the wires one by one?
Btw, my Civic didn’t come with original Honda radio but with a cheap pioneer radio. Not sure if that clarifies why it has a different plug.
Mekede support team said I need to get this one below.
