86salmon Lunar Silver Si
7Ghost_2Alienz_GenXX
Karo
South Carolina
20XIX Si
Long overdue update
It's been a minute since I've updated this and a few things have changed. Some are pretty big, some minor, but cool none the less.
First off. Eibach Prokit springs got installed along with the BMSpec front airdam I've been sitting on for a few months now (almost a year :confused1:). Had both installed at the same time at the same shop. They did it at a fair price, and I've continued to get work done by them.
Oooooh the stance, the fitment
Dat lip doe
I also did some lighting changes. I went from amber to JDM yellow fog light vinyl overlays to match my super bright LED highbeams. I had an encounter with some road debris that took out one of my fog lights. Lamin-x did its job though, and there was no crack in the lens. I took the opportunity to install some HID fogs in. I used some Xenon Depot bulbs I got on clearance and some DDM ballasts, both from Brisource.com . Borderline too bright, but the color and visibility in inclement weather... ? The glare might be dangerous though, and I'm debating on switching back to halogens.
Fogs only :cool:
So shiny
I also got a set of white smoked Helix side markers from Unity Performance. Rocking the harlequin two tone alla @CanadiaegeanBlue
So slick
And now, turbo time! I took advantage of tax time sales and got a PRL catted downpipe and the MHI TD03 turbo upgrade. The downpipe has added a nice growl to the stock exhaust note and even some burbles. I'm currently in the middle of a street tune for the turbo and will hit a dyno with results soon. Per the shop that did the install, the install was fast and the turbo bolted right up with no issues. Time will tell if the price difference over the W1 is worth it, but given my power goals, I'm ok with it.
Not really that big
Can you tell it's been done??
Most recently, I went full Acuity shifter add-ons. I added the cable bushings. I installed the smaller bushing upside down and posted the pic on IG. Acuity DM me and pointed out my error. I corrected my upside-down-ness soon after. Big props to them for the solid!!!
They definitely give each shift a satisfying finish everytime. I'm surprised how subtle yet substantial the difference is. The shifts just feel more solid and secure. I may make the jump to a full Hybrid or Acuity short shifter, but I don't know... This is pretty darn good.
As usual, sorry so pic heavy.
More to come...
Complete tune and dyno
Clutch?
Who knows what else
What size wheels you running? Will fitment be the same with me running 19x8.5” bbs wheels?
86salmon
86salmon
It's Hedley, Hedley Lamarr!
Chucktown, SC
I'm running 18x9.5 +35 with 245/40 tires
Not sure what 19' would be like. The tires would also affect it. I'd try a fitment calculator to see the differences. I like this one.
https://www.willtheyfit.com/
Anyone know where i can order the side skirts, rear diffuser, and wing from??? Thanks in advanced
I think that car is from Turkey. I'd check eBay and Instagram
Karo
South Carolina
20XIX Si
The issue with that wing is that when you remove the oem one on the Si sedan there are holes where plastic tabs hold onto the trunk lid (sucks) so now im stuck looking for the duckbill which in my opinion look better anyways
86salmon
86salmon
Chucktown, SC
86salmon
86salmon
Chucktown, SC
Subbed, cant wait to see what the turbo does. Glad someone is testing it out
Still getting the etune worked out. Hopefully I'll have it done and on a dyno sooner than later
86salmon
86salmon
Chucktown, SC
86salmon
86salmon
Chucktown, SC
oh noes...
My beloved floor mats have worn through... :cry:
Honda Civic 10th gen 86salmon Lunar Silver Si IMG_20200507_002120
The heel pad isn't wide enough for my clutch foot and wore through. I picked up
another set with a wider floor pad. They aren't as swanky though.
Honda Civic 10th gen 86salmon Lunar Silver Si IMG_20200507_011132
I guess I shouldn't expect much for the price. I'm gonna use this for daily, but considering I only wore out a drivers mat, I wanted to find a way to fix it.
I began to search for heel pads. I found a few rubber examples, but I didn't like their appearance. There was a black aluminum pad that wasn't quite as wide as I wanted. Then I found a
polished aluminum one. I wasn't completely sold on it's look, but it was the best I could find, so I pulled the trigger.
Honda Civic 10th gen 86salmon Lunar Silver Si IMG_20200507_002151
Packed in foam with hardware
Honda Civic 10th gen 86salmon Lunar Silver Si IMG_20200507_002209
Along with bolts, nuts, and washers came a punch. The old pad had small screws holding it on. They were easily removed with a Phillips screwdriver.
Honda Civic 10th gen 86salmon Lunar Silver Si IMG_20200507_002429
Honda Civic 10th gen 86salmon Lunar Silver Si IMG_20200507_002731
The extra width covers the heel hole and should protect from further wear :thumbsup:
Honda Civic 10th gen 86salmon Lunar Silver Si IMG_20200507_005223
Another comparison look
I used an original hole to start, and with the aid of the punch, bolted the new pad up
Honda Civic 10th gen 86salmon Lunar Silver Si IMG_20200507_004744
Honda Civic 10th gen 86salmon Lunar Silver Si IMG_20200507_004946
The mats have a bit of slide, so I added a couple Eagle Klaw anchors to keep them in place. It's a pretty nice kit with a sharp cutter to install the sharp spiked anchors.
Honda Civic 10th gen 86salmon Lunar Silver Si IMG_20200507_010742
The cutter is VERY sharp. Be careful with it. It went through the mat with ease and the claws screw together with ease.
Honda Civic 10th gen 86salmon Lunar Silver Si IMG_20200507_010720
Honda Civic 10th gen 86salmon Lunar Silver Si IMG_20200507_010706
In all, I'm pretty happy with the end result. I can feel the plate under both feet, and it's pretty comfortable
Honda Civic 10th gen 86salmon Lunar Silver Si IMG_20200509_073531
In other news...
I'm on yet another tune. My tuner has been slowly advancing timing. I'm eager to get on a dyno and see where the output ends up
Sorry I'm extra pic heavy this post
More to come...
fatherpain
Tom
Did someone say “pic heavy”? Heheh photos and step by steps are awesome ? keep it up man! Looking forward to seeing what’s in store!
More to come...
86salmon
86salmon
Chucktown, SC
New goodies
Got a couple things in the past couple weeks.
First up
Honda Civic 10th gen 86salmon Lunar Silver Si IMG_20200601_104532
A little bundle of joy from Acuity!
Honda Civic 10th gen 86salmon Lunar Silver Si IMG_20200601_105447
Esco in red and black and a ten pack of air freshener double cup sexy smell
Rocking the black right now
Honda Civic 10th gen 86salmon Lunar Silver Si IMG_20200609_195220
I've been using it for a couple weeks now. It's a touch bigger and heavier than the Mishimoto cf knob I'd been using, and works well with all the other Acuity parts. It's a nice cherry on top of the ice cream the Acuity shifter mods already are. Really finished off the great feel they added.
Now we'll see how hot it gets in the upcoming months ?
Next up... some maintenance type stuff.
From Autogeek
Foam sprayer garden hose attachment. Overrall it has a fairly study feeling construction
It has a quick connect to switch between foaming and rinse. There's a handy brass fixture at the nozzle to titrate your mix ratio. I'm currently using it with Meguiars gold class and a rinse bucket. I'm doing quick once over to presoak, then applying directly to my micro fiber wash mitt.
From S&B
Got a cleaning kit and a backup filter to switch to while the fresh cleaned filter dries and... Ummm... Cures? Lol while the oil sets
Honda Civic 10th gen 86salmon Lunar Silver Si IMG_20200609_203530
In blue of course.
Nice kit with a spray bottle and graduated measuring applicator for proper amount of oil per s&b filter specs
Honda Civic 10th gen 86salmon Lunar Silver Si IMG_20200609_203935
Last bit
AF Dynamic heat shield for cone filter
It comes disassembled, but well packaged.
Heat shield plate, adhesive backed insulation, and rubber trim
Honda Civic 10th gen 86salmon Lunar Silver Si IMG_20200610_113201
Honda Civic 10th gen 86salmon Lunar Silver Si IMG_20200610_113225
Honda Civic 10th gen 86salmon Lunar Silver Si IMG_20200610_113301
Honda Civic 10th gen 86salmon Lunar Silver Si IMG_20200610_114112
Honda Civic 10th gen 86salmon Lunar Silver Si IMG_20200610_114118
Assembly took five minutes
And...
Honda Civic 10th gen 86salmon Lunar Silver Si IMG_20200610_115419
Honda Civic 10th gen 86salmon Lunar Silver Si IMG_20200610_115415
Installed
I'll get some temps in the next day or two and see if it does anything other than look shiny
That's it for now
Sorry so pic heavy
Still waiting on next tune revision for MHI TD03
More to come!
905Civic
Mississauga, ON
2017 Civic Hatchback Sport Sensing, 2020 Kia Telluride SX
That heat shield intrigues me a lot, especially since my BMS is on the way (shipping delays of course). Will be keeping an eye on your temp updates!
n2da2nd
It's Senor Bane to ya
Nam
DFW
Last bit
And...
Installed
That's it for now
Sorry so pic heavy
More to come!
That heat shield rattles quite a lot in my car on low rpms so it's gone lol
