+37 or +44?
GoldClass
Singapore
Civic Hatchback
I have confirmed a set of wheel and the offset is either +37 and +44. +37 will rub abit on the fender tab but is dead flush. +44 will not rub but will short of 4mm to get flush.
If I pull the strut guide pin, it gives max. 1.0mm~1.5mm and yet not sure it will totally avoid the rubbing on offset +37.
Or I go with offset +44 and add 4mm spacer to get flush.
This is for 2017 Hatchback (non si).
What is your opinion?
yansag1982
Yanick
Montréal, Canada
2020 Coupe Sport 6MT
+44 and add a 5mm spacer later if you're not happy with how it is.
GoldClass
GoldClass
Singapore
Civic Hatchback
Thanks for the reply. I am lowered with pro kit. The width is 8.5 and I am getting 235/40R18 PS5. I know the shoulder of the tyre play a part, if all possible, I avoid any spacer - KISS (Keep It Simple Simon).
arpypat
You can run 18x8.5 +37 on 235/40 tires without any additional camber and you'll be totally fine!
WOPSiWOT
South Carolina
2017 Civic Si Sedan
I run 18x8.5 +38 with no rub and that's without even doing the fender tab.
GoldClass
GoldClass
Singapore
Civic Hatchback
Thanks for your reply. Mine is 2017 Hatchback. I know 2019 and above does not has any tab issue. Can you help to share some photos how close to the fender? TIA
WOPSiWOT
South Carolina
2017 Civic Si Sedan
Yeah, I have a 2017. I thought I'd have to do the tab, but have not had an issue. I don't have any images handy, but could pull some later.
GoldClass
GoldClass
Singapore
Civic Hatchback
Thanks. Are you on pro kit same as mine too? If yes, this give me a lot more assurance.
WOPSiWOT
South Carolina
2017 Civic Si Sedan
Swift Springs. I think that is pretty similar drop to Prokit. Good point though. That could make a difference. The Swift are also higher spring rate/stiffer I think.
GoldClass
GoldClass
Singapore
Civic Hatchback
Ah! That’s explained. Thanks for sharing.
Hondanickx
Belgium
I have 18 x 8.5 ET34 (235/40/18) and this rubs on the tab on stock height (Not yet lowered)If the center part of the rim has enough material you could always get it turned off a few mm .That's what i may (or may not ) do after its lowered . Turn down 4mm on a lathe and get ET38.
GoldClass
GoldClass
Singapore
Civic Hatchback
Thanks for your reply. Good thought but am concern about the integrity of the wheels and not sure if the lug nuts allow additional 4mm thread.
