3 or 6psi boost for flashpro?
CA
2016 Civic EXT
Looking for some opinions on whether I should go with a modest 3psi or 6psi boost with the basemaps.
Cheers.
If you are running decent fuel most would probably say that the 6psi base map is still conservative.
teebee288
Quebec
Civic 2017 hatchback sport, Mazda CX-3 2017, polaris rzr 1000s 2017
When i dynoed mine there was about 15whp and approx. 15-17wtq difference between +3 and +6 psi on basemap, i always run with +6.
CA
2016 Civic EXT
Any concerns with the stock bpv handling the extra boost or other potential wearing?
teebee288
Quebec
A lot of guys here on the forum run flashpro with stock bpv and no complain at all...for now. time will tell. If bvp start leak upgrade with boomba bov, or back to stock go to dealer to fix it and reflashed after.
45Lexroc
562 Los Angeles
'16 Civic Coupe Touring.' 06 Lexus Is250.
No Brainer, +6psi! Why would you spend $700 only to run +3. Out the box I was running +6 then switch to +6psi with Sri setting with AFE Takeda. Car is running reliably with 91 octane.
