AsianGuy98
- Apr 20, 2017
- 30
- 742
- 454
- Illinois
- 2017 Civic Si Sedan
How much more power can this turbo make?
Also, assuming this would be compatible with a flex fuel kit? Mostly have access to 91, but would love to try out a mix with some e85 if i got the chance!Power Level over 9000!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Blog is live now. Check it out.
https://www.27won.com/blog/the-w1-drop-in-turbocharger-pt5-power
Very impressed!!!Power Level over 9000!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
We still have not found it's absolute limit. But the delta is impressive. An easy +50 whp on pump gas is a good bump in powerHow much more power can this turbo make?
You should still net some solid numbers. We have another SI this will be going on shortly that is all stock and I can share those when we get them.I want to know the increase from a custom 91 octane only tune. Lots of us have no access to E85. With no bolt ons, all stock.
There is no reason for a flex fuel setup to not work. Huge benefits for those that take advantage of it, especially with 27Won’s new setup.Also, assuming this would be compatible with a flex fuel kit? Mostly have access to 91, but would love to try out a mix with some e85 if i got the chance!
I very much believe you can get right at 300 with 93 fully bolted and a little bit more boost. But it's important not to get hung up on the overall number as all dynos vary. It's the Delta that we are after. You are basically dropping in an extra 50+ whp with some tuning.@Vincent@27WON what's the possiblity of me making 300+ whp on 93? Full bolt ons.
Possiblity of making power passed 7k rpm? Or would I need some head work to rev that high with the added power?I very much believe you can get right at 300 with 93 fully bolted and a little bit more boost. But it's important not to get hung up on the overall number as all dynos vary. It's the Delta that we are after. You are basically dropping in an extra 50+ whp with some tuning.
